Question about T-Mobile MDA Vario Smartphone
MDA Vario from T Mobile. having Display problem. Who can fix it??
1. I have MDA Vario from T Mobile. It has a display problem. Mostly on today screen it works fine but when I go to in side a menu which has white background, Its screen gets white slowly slowly and stop working. I press power on of button to reset screen.
2. how Can I change white color of email window, phone Dialer and other submenu windows. I never changes with changing Themes.
SOURCE: priblem in starting T-Mobile MDA Pro
Try to remove the Micro SD card from your MDA
Posted on Apr 29, 2008
wykidtech
  • 99 Answers
SOURCE: My nephew give me Gift MDA T Mobile vario from U.K
This method will erase all the data on the device and restore it to factory defaults:
Hard Reset T-Mobile Vario
Posted on Mar 20, 2009
  • 18 Answers
SOURCE: t mobile mda pda ohone repair
Try http://www.pdasmart.com for your smartphone repair needs!
Posted on May 25, 2009
  • 22 Answers
SOURCE: how can i restore my contact on mda vario 3 after
if you have bluetooth on your pc set it up, or usb connect, or usb connect and run cd that came with phone
Posted on Jun 14, 2009
VinayT
  • 1884 Answers
SOURCE: Window in not starting
Findout from MDA site what is the 'reset to factory default settings' is. Remove the memory card and reset. It will do away with the new SW that you installed. You will loose all settings that you made and the SW that you installed. But your phone will be as good as brand new. In case of Nokia the code is *#7370#. Yours may be different.
Posted on Aug 06, 2009
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
The screen lights up when i switch on my mda vairo but does not show the normal screen to allow you to use the phone
hey u are having problem with with display and kit connector...... u have to change it..... go to nearest customer care.......it wll cost u very low
Mar 19, 2010 | T-Mobile MDA Vario II 1000 Smartphone
T mobile mda vario 2 of USA and now I want to use it in india so for that i need network unlock code
u can find info via this thread!
http://forum.xda-developers.com/forumdisplay.php?f=254
Mar 03, 2010 | T-Mobile MDA Vario II 1000 Smartphone
My phone the MDA Vario wont installm on my windows
download activesync
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Dec 04, 2009 | T-Mobile MDA Vario Smartphone
How do i unlock htc wiza200 mda
There is a very straightforward solution now, thanks to some helpful peeps at xda-developers forum. Simply download a zip file called lokiwiz3a.zip (Google is your friend).
I used it yesterday and had generated the unlock code within minutes of connecting the MDA Vario with my laptop.
Oct 12, 2009 | T-Mobile MDA Vario II 1000 Smartphone
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
My pc is not detecting my T-Mobile MDA
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
May 13, 2009 | T-Mobile MDA Vario Smartphone
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
Aug 16, 2008 | T-Mobile MDA Vario Smartphone
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
T-Mobile MDA Vario Smartphone Logo
195 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
