Question about Electrolux Vacuums
Electrolux discovery 2 upright service manual
2 Suggested Answers
  • 430 Answers
SOURCE: My repairman moved so I need to service on my own
Excellent question, however a D3 is basically a problem free vac. All you need to do to maintain it is keep a stock of fresh 4 ply bags and periodically remove the lid from the head and clean out any dust and dirt building up around the motor or brush roll. There are 5 philips screws recessed in the lower housing , accessible from underneath the head , Once removed the lid will lift of and you can vacuum any dust away from the motor and brush roll. There are two hex nuts holding the power head motor in place and if loosened they will change the tension on the brush roll and belt so check the tension before tampering with them.
NOTE On this vac a properly installed brush roll will stop the motor and kick out the breaker/reset on the vac if the brush roll is gripped firmly against the brush opening with a hand securely gripping it.
I mean grab it VERY tight or you will have it slip and blister your fingers. If the belt / motor position is too loose or if the belt has a broken tooth, it will rattle like a machine gun , because it is slipping.
If too tight it will kick out the motor rest continually.You can periodically remove the belt, turn it inside out for inspection and examine for cracking or loose teeth by rolling through your fingers and pull the brush up and slightly forward from its housing to inspect for hair and thread at the end of the brush roll. There are recessed ball bearings inside the wood on the brush roll and they need to be kept clear of buildup on the outside.
Spray any wheel squeaks with wd 40, with the straw in place, justy a quick burst and you can also do this on the very end at the centre of the Power head motor , however DO NOT spray the carbon brush copper surface area as WD will burn. If you are very methodical you can actually remove the carbon brushes which are offset and clean them with a dry cloth and inspect for chipping and wear. Pay attention to their position and do only 1 at a time. That's all. Electrolx 101.
Post back with how you make out.
PS parts come from an AERUS Electrolux source but a good pro vac shop can give you great service too as this same vac is now sold under several labels.
Posted on Nov 01, 2009
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
I am looking for the Owners manual for Electrolux Discovrery iii vacuum
o to
http://www.aerushome.com/Site/Manuals
Under older models in the drop down box you will see Discovery iii
i work in a service center we carry parts for this model in Beaumont TX aell all over though.
Jan 24, 2016 | Electrolux Vacuums
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
I have an Elextrolux Discovery Advantage(upright) . I need to replace the lower hose. Unfortunately the hose comes out of the roller/feeder area fine but I believe it is held in with a screw in the...
It's simply screwed into the tank. Simply unscrew in a clock-wise direction to remove. To install the new hose, screw in in a counter-clockwise direction. This is opposite the direction normally used for regular screws.
You don't need to dismantle the tank at all.
Nov 03, 2010 | Electrolux Vacuums
I am trying to get a user manual for an Electrolux Vitesse 1600 upright vacuum cleaner for my mother in law. Thanks
I've been trying to get a manual for my mother in law for years ;)
You didn't specify a model number so I'm not sure this is the correct manual, but it is for an Electrolux Vitesse 1600w upright. This manual is for model number Z4703AZ:
http://www.electrolux-ui.com/2007/755/98BEN.pdf
Click the link and the file will open. You can then view, save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
If you have a different model, please post back with your correct model number and I will provide a link for the correct manual:
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | Vacuums
How do you get into Elecrolux Discovery Upright to replace bely
make sure you got all the screws, and then gently pry the cover off, its probably never been off i presume , have some patienc and you'll get it
there may be a fifth screw
Jan 16, 2010 | Electrolux Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Beater bar stopped on discovery 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=605948
Posted by steve6335 on May 18, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
Go Ahead. Use Us.
May 18, 2008 | Vacuums
Vacuums Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
