Question about HP OfficeJet 6210 All-In-One InkJet Printer
Can send fax but not recieve
I can send a fax, but when someone tries to send one to me they just get a busy signal. Phone connected to the same line works fine.
  • 45 Answers
Hi Mark
Please check the following link to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00297388
Thank U
Posted on Jan 22, 2009
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I CAN SEND FAXES BUT NOT RECIEVE
The majority of the time, when you can send but not receive, it is a phone line issue and not the machine. Extremely rare does a machine send and not receive. So here goes the things to try and the reason. 1, Make sure the phone jack is in the "Line" jack and not the external phone jack. Believe it or not, that is the number one issue with sending and not receiving.
Next, plug a phone into the jack that the fax machine is plugged into and see if there is static.
You want to be sure in the fax \settings and advanced settings that the ECM mode is ON, and that Junk Fax ius turned OFF, Junk Fax being on will stop almost all fax from comming in.
Now, the phone line. Here is the explaination of why that can be the problem. When you send a fax, you manually make the connection to the line. When you press send a relay flips and connectes you to the phone line, therefore you have made pretty much a mechanical connection enabling the phone line, and therefore you can send.
Now, when you have an incoming fax, several conditions must me met to make the handshake and therefore connect and receive. These all have to be right in order to properly receive. The phone line voltage mist be high enough, the phone line current must be correct and there can not be much decibel loss over the line. You are making a signal connection, all those conditions must be right to receive a fax. Think of it like a TV remote with batteries that are almost dead, It still send out some signal, but it will not change channels or change the volumn,etc etc. Same principle. If the signal to the incoming fax is weak, chances are it will not connect.
Jun 13, 2009 | Office Equipment & Supplies
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Won't fax or recieve faxes
Make sure your phone cord is connected to the LINE port of the fax machine.
Nov 25, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
2 phone lines causing problems for fax machine
1 line is fine as long as the fax is set to auto recieve mode
Nov 12, 2008 | Office Equipment & Supplies
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Busy signal on sending and recieving
Did you plug a phone into the phone jack and see if there is a dial tone?
Thats the first place to start.
After that let me know, and I will give you more ideas.
Sounds like a phone line issue
Dec 12, 2007 | Brother IntelliFAX 4100 Laser Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
76 people viewed this question
Ben Johnson
