Question about Prima Televison & Video
The prima tv model number ph4327p stays on for a few seconds then turns off
  • 541 Answers
SOURCE: prima lcd tv, model number lc27r25 wont turn on
Most likely there is a problem in the power supply. Sets these days are so full of safety circuits that most any problem will cause one to not come on. Hard to say. Thanks
Posted on Oct 29, 2009
  • 308 Answers
SOURCE: 32 inch prima lcd tv model lc-32u16 that won't turn on
You probably have some defective filter capacitors in the power supply. The tops of them may be domed instead of flat. Be sure to replace them with same values listed on the originals - slightly higher voltage rating is OK, but no less! Make sure they are rated at 105 degrees C and not 85 degrees.
Posted on Apr 03, 2010
  • 11 Answers
SOURCE: nedd Prima TV/DVD Model # CV2011 codes for remote
Try the samsung code.
Posted on Jun 08, 2010
freetek
  • 5568 Answers
SOURCE: model R61Wh76 projection tv turns
Try the following- Before you turn it on, set a large fan ("breeze box") or similar behind the set and aim it toward any lower openings you see.
If this lengthens the time before it shuts down, then a cooling fan normally found in the lower cabinet area is not running. Those sets can have significant hot areas and may have a thermal shutoff to prevent fire in case of a fan failure.
Posted on Jun 15, 2011
  • 149 Answers
SOURCE: prima television model number CTV3442SR.
check your settings and your manual
Posted on Sep 23, 2011
I'm looking for the remote code for the PRIMA LC-20Y15 television in order to activate my remote control for my Bell Satellite system. Any ideas? Thanks
The remote codes are here.
I didnt see the Prima LC, but you can still problem with the instructions below.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Dec 21, 2010 | Televison & Video
Prima model number cv1311 will not power up
good day. there are some parts to be tested. just resolder all pins of jungle ic. make sure that the board has no loose connection, try to check them all. then try to on your tv.
Jun 21, 2010 | Prima CV1311 TV
My prima tv suddenly says
You took the TV out of the mode for either satellite or cable and it need to be reset . check the user manual for the setting.
You didn't give model number for the unit/ I may be able to get you the instruction for you to reprogram the tv.
Apr 23, 2010 | Prima C2012 TV
I have a Prima P5017 TV I need the specs. I need
I have a Prima TV Plasma Model P5017 The TV turn off alone and when I try to turn on the red light change to the blue and five seconds later turn off.
Mar 28, 2010 | Televison & Video
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
Prima lcd tv, model number LC27R25 wont turn on
Oct 21, 2009 | Televison & Video
It could take many hours before I can open my Digistar TV. I put power on, the blue light appears, but the screen stay dark and no sound. After, it's impossible to turn off the TV. I must to disconnect the...
I am having the same problem with our prima lcd tv.I contacted an expert who said we just needed a new power supply board which is about 35 dollars.The only problem is is that Prima is no longer in business and am unable to find anyone who can find part numbers for this brand and their phone number is disconnected and their web site is as well.Sorry I can't be of more help.
Feb 18, 2009 | Prima CV1311 TV
Hooking my Prima DVD to my cable TV
i have a problem with my tv i ddidnt receive my book for the set up and now i need to know how to set up my prima PH4327P
Feb 07, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
