Error Code... Hi Cogz... Thanks for answering my public questions. I have more, hope you don't mind about it : 1. my IR 6000 show E00061-0001 or E00061-0002 after it is fixed by a technician. Actually it runs well for the first time, except it always gave black spot at the left-bottom corner of A4 or letter-sized paper. But if I set them to R position, it's OK. Then I asked them to be repaired but now the error code above is appeared and I can't even use the machine. What do you think about this? 2. my IR 5000i is turned off for itself and after I turn it on, it shows E00002-0000 code. I try to turn it off and then turn it on again but no effect however. What is this means?
  • danar308 Feb 15, 2009
    Thanks for answering. My 1st problem is resolved. It happens to be the technician I once hired was not careful when placing a conector back. He broke it and that's the main cause. I called another, they replaced it and it is solved. The black spot was because the lamp was misplaced. After it was fixed, my machine is running fine now.
    And about my 2nd problem, it sometimes shows me E00002-0000 code, and sometimes it doesn't. At the screen, it was hung at the Canon logo condition, and can't enter the main page display. They told me it was probably because of the main PCB controller faulty. BTW, just curious, could it be possible if it's because of software problem?
    Thank you
  • 1,326 Answers
Problem 1 is most likely a problem with the primary corona unit... The grid wire is arching to some part of the unit - it code also be that the post wire are strung to loose and the corona wires are bouncing and arching. It sounds like there is something wrong with the corona unit. Have them change the 2 post wires and make sure the grid is clean and that none of the wires are crossed.
Problem 2 A E0002 is a fixing error code. It means that the fuser is not heatting up in time or that is not turning "ON". Most likely you can clear it in service mode, but if that dose not work it could be a blown thirmister or thermal fuse or the fixing lamps or all 3. If it can be reset, the problem may be a power problem from the outlet. Good Luck......
Posted on Jan 22, 2009
  • Chris Coughlin
    Chris Coughlin Feb 16, 2009
    The little black dots or spots are caused by the primary Grid wire. Have you repair person make sure the grid wire is not crossed. Also, make sure the corona wires are not gold or zinic plated. They should be using a brownish color corona wire. If they used gold plated you may get black spots. Problem 2# you need to get into service mode. Press the "additonal funcation" botton once then the numbers 2 & 8 at the same time then the additional funcation once more. The display should change change. Press the "Copy" tonthen press the "Funcation" botton on the display pannel, the screen will change again. Then press the "ERR" botton, then the screen changes, then press the "CLR" then press the "OK" and turn the copier Off, the Main power switch OFF on the right side.Then turn it back "ON" if that dose not work, you have more problems with the fixing unit.
Canon ir 6000 ranning copy machine hang 2minet before e733
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
Feb 07, 2015 | Canon imageRUNNER 6000 Copier
Hi this is irfan i have canon ir 3300 last 2 day it show this error code repeat when i clear the error code the comes back that error code. i replaced fuser fixing film and pressure roller Please help
Re: E000 Canon IR3300
The fixing film unit is faulty. The main thermistor has an open circuit. The fixing heater has an open circuit. The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR
Secondly Irfan, keep in mind, if you changed out the fixing film inside the fuser unit, then more than likely you did not reassemble the fuser unit while making sure the sensors were "EXACTLY" the required depth from the fixing unit.
When those sensors are even SLIGHTLY off, it will code out because they cannot read the temperature correctly when they are too close or too far away.
And when I say they have a very STRICT tolerance, I mean you actually need to get a depth gauge and check to ensure they are perfect.
I'm a copier technician, and quite honestly I rarely do a rebuild on Canon fuser units because they are so strict on these sensors.
I can also recommend a GREAT company that does nothing but rebuilds for fuser units. And they specialize in Canon models!
I'm not sure if they deal with the general public, or just dealers, but you can certainly call them and find out. They are called "Fusion Image Technology - Their website is www.fusionimagetech.com - Hope that helps.
Aug 24, 2014 | Office Equipment & Supplies
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
Please help me that i dont have code for ford ka 6000 cd rds e-o-n m024904 Thank cheers mate
Have this decode spftware I purchased for my business which seems to work about 80 percent of the time. I ran your serial and it gave me a code of 3737. Let me know if this is the right code if you don't mind. I want to know if I got my moneys worth. You can comment here or email me at csautomotivecars@att.net to let me know if you don't mind. Hope it's right for you.
Jan 08, 2012 | 2001 Ford Ka
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
IR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Jan 21, 2009 | Canon iR5000-6000-L1 PS Ver 1.0
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
499 people viewed this question
jasbo
jasbo
