Question about HP Compaq Presario CQ57-229WM Notebook PC
The spacebar key has come off the keyboard on my compaq presario cq57. How do I put it back on please
    New Friend:
Glue it with either Super Glue or apply Ados to both the key board side and the back side of the key and then press together after 5 minutes.
Posted on Jan 10, 2013
leecom72
  • 4806 Answers
SOURCE: How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Posted on Nov 13, 2008
leecom72
  • 4806 Answers
SOURCE: changing keyboard on laptop
Hi there
Putting the keys back in place can be a tough job especially if the cradles have snapped, your probably better off replacing the whole keyboard as it will be cheaper for you.
As it happens HP laptop keyboards are really easy to remove, if you look under the laptop you will find 2 screws clearly marked with keyboard symbols next to them, unscrew them and turn the laptop right way up and open the lid. At the top of the keyboard look closely for 4 small plastic slide locks, just slide them back and you can proceed to remove the keyboard, be very carefull at this point because there is a delicate ribbon cable which you have to remove from the motherboard.
Once removed your good to go!!!! just follow the instuctions in reverse to put it back together.
Kind regards and Merry Christmas
Posted on Dec 23, 2008
  • 13 Answers
SOURCE: Keyboard Keys Mismatch error
this could be caused by a couple of different issues:
1st Depending on the operating system you have loaded, it could have the wrong keyboard type or emulation selected.
2nd The keyboard or its cable could be bad, it will not necessarily quit until it goes completely out.
Posted on Mar 07, 2009
  • 597 Answers
SOURCE: problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Posted on Nov 06, 2009
Geekman
  • 32281 Answers
SOURCE: compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Posted on Feb 24, 2012
How to do a Screenshot on a Compaq Presario CQ57 Keyboard?
1. Hold Shift key then press Print Screen.
2. Open Paint, Hold ctrl and press v.
3. Save it as per your requirements.
Thank you...
May 08, 2015 | HP Compaq Presario CQ57 Laptop
I have a compaq Presario CQ57 laptop and cannot get the up/down etc arrows to work. Don't have a numbers lock key so I don't know how to get them to work again.
Here are some options:
1) Use an external number pad
2) Use an external keyboard
3) Replace the keyboard (a small Phillips screwdriver and a flat head are all that are needed.)
Amazon com cq57 keyboard
Oct 01, 2014 | Compaq Computers & Internet
Where is shift key on compaq cq57
As usual the shift key is on the right bottom corner second key up!
SEE PICTURE BELOW:
http://www.coywood.co.uk/ekmps/shops/jimbocoy1/images/compaq-cq57-keyboard-uk-3225-p.jpg
Jan 21, 2013 | Compaq Presario 700 470024-192 Notebook
Compaq presario cq57 keyboard wont work
Hi ,
Yes it can , If you know what your doing , open the laptop up to expose the keyboard , then clean and dry the keys very well and put it back together , let me know what happens ,,,,,,Goodluck Roy
Oct 30, 2012 | HP Compaq Presario CQ57 Laptop AMD DC...
How do I disable the wireless key on Compaq Presario CQ57 keyboard ?
We have several terminals with keyboards that are used by different people during the course of the day. We had a similar problem with the Caps Lock and Num Lock keys. Solution(s): Straighten out a paper clip and make a quarter inch hook at one end. Insert the hook under the offending key(s) and pop it up. You can easily replace the key should there ever be a need. No ham, no foul.
May 30, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
Compaq presario laptop
full keyboard replacement is recommended as the brackets to place the keys are not sold
Mar 23, 2008 | Computers & Internet
HP Compaq Presario CQ57-229WM Notebook PC Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
