HOW I CAN GET ORACLE SQL SOFTWARE? - Computers & Internet
  • Asaph
    Asaph May 11, 2010
    Do you already have Oracle? Do you just want software to look at your data structure files?
  • Austin Evans
    Austin Evans May 11, 2010
    What Operating System are you running?
    President:
  • 392 Answers
I think it's not free and it has a large size to download, but maybe you fnd it rarely.
Tip: Look in rapidshare!
Posted on Feb 13, 2009
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Access sql database using C.
Please go for the ORACLE 8i or higher, it has a utility called proC, in proC you can create program to access any database in Oracle or SQL server.
After compiling program in proC environment, it will create C code for tha same logic, that you can compile and use in C enviromnent
goodluck
Zulfikar
Mar 10, 2009 | Computers & Internet
What is an sdf file and how it creates from which application.
.SDF File Extension (SQL Database File), the filef ormat for Microsoft SQL Server Compact databases.
Please rate this a fixya
Jan 30, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
About sql*plus of oracle 8i
Can you clarify your question?
For instance, where do you need to create the username/password? Oracle?
If you are asking for the sql to create a user in Oracle, it is very simple:
(change the items inside <> to your needs)
sql> create user <username> identified by <password>;
At this point, keep in mind that the user has no privileges, so the user will exist, but will not be able to do anything on the database.
Hint: What I like to do when I am in a hurry is create the user as follows:
grant <role> to <username> identified by <password>;
This command will create the user, assign it the password you gave it and grant the ability allowed by the role in question.
Hope this helps!
Jan 16, 2009 | Veritas Cluster Server for Solaris Oracle...
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
How to develop a tool for conversion the database from sybase to sqlserver
ahh..sudeep...it is a truly glorious day for this work. The detailed solution is to call Larry Ellison, at Oracle, and enquire if you can have his code.
Apr 23, 2008 | Computers & Internet
How to connevt visual basic with oracle(sql)
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Jan 23, 2008 | Computers & Internet
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
Computers & Internet Logo
David Payne
David Payne
