I found a panasonic sb-w95 but the wires are cut off close to the box can I open this up somehow
Sb-w95 sub woofer the speaker wires are cut off close to the box
SOURCE: Sub Woofer will not work with my other two speakers.
ok SB is for surrond back. but i think i now what the problem is. if your receiver is in multi channel decoding some times the bass will olny come out of your main speakers. and how to change this is go to SET UP in main menu on your receiver make sure you got NORM SET on and then go over in tell it has your main speakers highlited and change that to SMALL not LARGE and sarry for the spelling hope i helped
Posted on Jun 27, 2009
tech240
  • 169 Answers
SOURCE: bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Posted on Sep 20, 2009
THENTHEREWER
  • 131 Answers
SOURCE: im trying to hook up a sub-woofer to my reciever.
You can get rca jack ends at any electronics store.So no you don't need a new sub.
Posted on Jan 09, 2010
  • 13 Answers
SOURCE: sub woofer speaker wire
Probably an RCA Pin plug
Posted on Jul 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: HI i have Panasonic SB-WA330
Not unless it's a similar Panasonic main unite. There's that pesky special connector "A" (so common on all-in-one products) to deal with.
The picture here http://www.forodvd.com/tema/97518-duda-usar-nuevo-ampli-con-altavoces-antiguos/ shows it requiring an SA-HT810 or SA-ST1 source.
Even beyond that speed bump, most stand-alone DVD players have no facilities for on-the-fly adjustment of volume. That is one reason why they make main units.
Posted on Sep 03, 2011
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
Tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
Tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
Wiring assignment for plug of Panasonic SB WA340
my woofer lost the sound I.C how can i solve this problem?
Feb 13, 2010 | Panasonic Audio Players & Recorders
Power to subwoofer but no power to SA-HT692 receiver.
I had the same problem although not in storage but it just lost power to the console. It turns out that when I press down on the cable connecting the sub woofer and console, at the back of the sub woofer, I temporarily get power to the console. I did that for long enough to eject my DVD's and then opened the back of the sub woofer to fix it and cracked the board and broke it forever.
Sep 20, 2009 | Panasonic Audio Players & Recorders
Tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
How do I remove and replace the rear speaker in my 2002 Lexus ES 300?
Hello, I have a 2000 ES300 and while the body style is different believe the newer model still has the rear deck mounted sub-woofer that you are referring to. The process of removing this speaker would start off the same as if you were going to replace the third brake light also located in this housing. Using a flathead screwdriver work your way around prying/popping up all four corners of the speaker grill covering the speaker that have the retainer clips. Once you disengage the clips work/maneuver the grill up and towards you gently and it should slide out. The bulb for the third brae light will be attached to this speaker grill, disconnect the snap wire from the bulb and you should have a clear visual of the speaker and the four bolthead screws securing it. Remove these screws and your almost home free. The next part might be slightly more difficult. If the speaker s simply connected by a clipped on wiring harness, just detach.On my 2000 ES300 i have the pioneer system(Not Nakimichi) and the 2 wires (one black, and one red) are soldered directly to the speaker. You can take a soldering iron(maybe a battery or gas powered one unless you have an inverter) and remelt the solder to remove the wires or you can elect to simply cut the wires. If you choose to cut them make sure you cut them as close as possible to the soldered joints so you have plenty of wire left to install the replacement speaker.Then install replacement either soldering or using crimp clamps and reassemble. ( Note if you simply want to add a aftermarket amplified sub-woofer you don't need to remove the sub-woofer out of the housing. You can tap into the wire leads and run it directly to the amplifier. Just cut one of the wires leading to the stock sub-woofer so it doesn't also come on and potentially blow while the radio is on. This will also prevent any bass humming when the radio is shut off but the aftermarket amplifier is still on because once one of the wires to the stock sub-woofer is disconnected or cut it breaks the circuit. Hope this helps.
Jun 13, 2009 | 2000 Lexus ES 300
PANASONIC SURROUND SOUND SB-WA3300
May be wrong number. SB-WA330 is name of speakers and search http://safemanuals.com/ to give you the right manual
Samuel
Aug 18, 2008 | Panasonic Home Theater System System
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
51 people viewed this question
 Grubhead
Grubhead
