Question about Building Materials
What is laminated Floor? - Building Materials
    Habit-Forming:
    New Friend:
  • 16 Answers
Laminate flooring is created when four layers are synthesized into one extremely dense surface.
  • Wear layer - A clear, top layer that provides resistance to stains and fading
  • Design layer - A high resolution, highly-detailed photographic image that realistically captures the look of genuine wood
  • Inner core - high-density fiberboard (HDF) made from wood fibers fused with resin. HDF is an engineered wood product that's strong, hard and dense, and keeps the laminate board stable, flat, and moisture resistant.
  • Backing - A moisture barrier backing that protects the floor from warping
For more details Calgary Carpet Flooring Stores Calgary Homefloors
Posted on Oct 14, 2015
    New Friend:
    Problem Solver:
  • 5 Answers
Basically, laminating is the result of a direct pressure process that fuses four layers into one durable surface. The laminating technique originally came from Europe and spread worldwide in the last decade.
Posted on Jan 10, 2013
NOt t all happy with my 1year old style selections laminate floor. It creaks with every step. Has hooked up
contact the floor layer who did the job and check on the work and material warranty
Sep 16, 2017 | Building Materials
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
Can I put laminated floor over my carpet?
Laminated floors are possible to install over virtually any type of floor you have although over carpets and especially high-pile carpets it is not advised.
Feb 06, 2013 | Building Materials
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
How much should I spend on a laminated floor?
In general, laminate floor will cost between 1 to 6 dollars per square foot, depending upon the quality of the design and its thickness.
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Building Materials Logo
446 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
