Question about E-Machines eMachines Desktop PC
Computor why do i have 3 red lines running down left had side of screen the computor is only 1 month old
    Genius:
  • 1,102 Answers
Is there a menu control for screen
If it's only 3 months I'd talk to where I bought it
There should'nt be red lines has it always done this
Posted on Jan 23, 2009
Samsung plasma 42inch 1 month old has got 1 thin blue line 2 thin green lines from top to bottom on left side of screen
Most likely your control board: The board with the large processor that controls most of the picture formation is bad. Sounds like it is under warranty if it is only a month old.
Feb 23, 2010 | Televison & Video
Red thin line on left side of screen / black colours have a burnt red tinge over them. TV is 30 months old
If that line is permanently on the screen  - even when you are using the AV signal then the LCD panel is busted, no way to repair it. Try getting it replaced under warranty, it shouldn't have failed so soon
Oct 30, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
Vertical lines in my laptop screen
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
E-Machines eMachines Desktop PC Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
