Question about JVC HD-70G887 TV Lamp with Housing
Where in the lamp door on the JVC HD 70G887 TV
SOURCE: JVC HD-56G886
Call your cable company, the lamp has nothing to do with the inputs, Maybe one of the connections is barely connected from moving the TV to replace the lamp.
Posted on May 11, 2008
  • 147 Answers
SOURCE: JVC HD-61Z786 Projection TV:
There is either dust on the lens or there is a problem deep within the light engine. This is a some-what common problem with these sets. The light engine is very expensive; not economical to repair.
Posted on Mar 30, 2009
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
  • 12 Answers
SOURCE: How to get to the lamp to replace it
I dont have a manual either but when I replaced one on the hd-56g786 I just took the screen off by removing 10 screws and had a ton of room to do it
Posted on Feb 08, 2010
  • 3 Answers
SOURCE: jvc hd-61Z786 REAR PROJECTION TV . is dark.
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Posted on Feb 23, 2011
NEED MANUAL 70G887
You may get some manuals from http://www.manualsonline.com/ or http://www.makeuseof.com/dir/manualsonline-free-downloadable-manuals/ ...
Nov 03, 2012 | JVC Televison & Video
JVC HD-56FN97 Alternating Power LED/Lamp LED
check the supply voltage if it is working in the ballast board, if this is a new lamp you must need to reset the lamp hour.
Aug 28, 2012 | JVC HD-56FN97 56" Television
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
The TV toll me to some light was ready to expire. What do have to buy??my screen is off.
Your tv needs lamp replacement that was said, required lamp for tour JVC HD-56G787is available with discount-merchant.com for $135
Replace lamp in tv to get its picture back, call local tv repairman to replace lamp if you feel uncomfortable doing so.
Thanks.
Nov 16, 2010 | JVC HD-56G787 Television
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
JVC HD-56G886
May 06, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-70G887 TV Lamp with Housing Logo
26 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
