Question about Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC
"error starting the service Backup Exec & media service"
When i run Backup Exec 10.0 on my NT server it gives me the following errors
1. Error starting the service Backup Exec Agent Browser" The service didi not start due to a logon failure
2. Error starting the service Backup Exec Device & Media Services
3.Error starting the service Backup Exec: Server. The dependence service or group failed to start.
4. Error starting the service Backup Exec: Job Engine. The dependence service or group failed to start
  • Anonymous Apr 02, 2009
    I have the same problem Imran
  • Anonymous Mar 12, 2014
    backup exec 10d exchange agent
This is most likely caused by a change in the user acount password that you created the profile with. Under network select Logon account Managment. in here you will see the accounts that you used to login to the Domain. (AD) Consider setting up separate accounts (backup, etc) for these services & scheduled jobs, rather than using the admin or personal accounts. This way you can still change the admin account password on a regular basis & maintain security, but not have to go the hassle of updating all of these at each change. You may also opt to set these specific accounts so that the passwords do not expire automatically so that you do not have to deal with that scenario.
Posted on Jan 23, 2009
Corrupt Exchange DB - Help!
If exchange server database is corrupted due to improper server shutdown, power issues, JET errors, drive errors, corrupt header errors, server down issues, and server crash incidents etc then exchange edb repair can easily fix following issue. Read more http://www.edbrecovery.edbtopstfile.com/
Jan 30, 2015 | Microsoft Exchange Server for PC
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
After a full back-up was made, the tape stays in the drive
Click Start, then Run, type in services.msc and hit enter
Look for the Symantec (Veritas) backup Exec Tape engine service and stop it by right clicking it and hitting stop.
Eject the tape.
Restart the service.
Dec 17, 2009 | Veritas Backup Exec 10 for Windows Servers...
Printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Oct 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
Printer not printing
if your printer is giving you an error msg saying printer communication not available.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day :)
Oct 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
System State Backup problem
That specific error pertains to "validating" your copy of Windows. you might want to validate that copy, then re-try system state.
~~Jasta~~
Mar 24, 2008 | Microsoft Windows Server Standard 2003 for...
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC Logo
2,406 people viewed this question
Top Veritas Computers & Internet Experts
Jax Planet
Jax Planet
Mike
purushottam aher
Level 1 Expert
Are you a Veritas Computer and Internet Expert? Answer questions, earn points and help others
