Question about GE Profile JTP56 Electric Double Oven
My ge jtp56woa1ww double electric oven lower oven will not bake or broil
2 Suggested Answers
  • 447 Answers
SOURCE: my ge jtp56woa1ww double electric
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Posted on Oct 08, 2010
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
JKP86-27 neither heating element (broil or bake) is working. Other controls and microwave work fine.
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Nov 25, 2010 | GE JKP86 Electric Double Oven
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
