Question about Epson Stylus DX4450 All-In-One InkJet Printer
Epson stylus dx4450 wont grab the paper
Tried printing out a document and the printer wont grab hold of the paper, no obstructions , jammed paper any solutions?
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
SOURCE: Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Posted on Jul 29, 2009
pineworks
  • 4041 Answers
SOURCE: epson stylus dx4450 printer does not print black.
Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Feb 28, 2010
The paper gets jammed it starts to go in but then it like crumples up and gets stuck
check if the back panel that you can remove to check for paper jams has come loose. If it is the paper can get snagged on it and jam. I don't have your model printer but most printers have this access panel. It is usually the same part that can be replaced with a special part to enable two-sided printing.
Jun 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
My red and green light wont stop flasing. i have put new cartridges in.
If the pair is the green power light and the red paper light that are flashing, then you have a paper jam. You need to check the paper path (it's possible that a small piece of paper tore and is causing the jam).
I hope this helps.
May 21, 2010 | Epson Stylus DX4450 All-In-One InkJet...
My Epson Stylus Photo RX580 had a paper jam. I cleared it but now the screen keeps saying "Printer error has occurred. See your documentation". I've turned it off a few times and I don't know what needs...
1. turn it off & disconnect from computer
2. open printer & check for any obstructions
3. load a sheet of paper, press & hold the paper feed button while turning the printer on
4. it should print a test page, else the printer needs service as there might be some no-user serviceable parts inside that got damaged by the paper jam.
Apr 05, 2010 | Epson Stylus RX580 InkJet Photo Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
DX4450 goes through motions of printing document but at the end there is nothing on the paper. Ink cartidges are full.
Did you just install the Ink Cartridges? If yes, did you take off strip?
Shut it down and wait 15 minutes, then turn back on.
Good Luck
Nov 03, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Hello i changed the ink in my epson stylus dx4450 however the ink light is still on and it still wont print. i tried turning it off at the plug but still wont work
It seems that the connection on the cartridge and the printer are not proper. Remove the cartridge and clean the connectors on the cartridge and the printer. Also remove the tape on the print head.
Aug 28, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson STYLUS DX4400
Have you removed the pull off tape from the top of the cartridges, it lets air in enabling the ink to flow, easy mistake!
May 27, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson STYLUS DX4400
Dump then program. Start your pc again wtih printer plugged in. Let it install program automatically.
Feb 21, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus DX4450 All-In-One InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
