Question about Epson Stylus CX4800 All-In-One InkJet Printer
Epson stylus tx810fw says its printer offline!
While printing from macbook using wireless the printer constantly comes up saying its offline
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: epson stylus dx4450 printer does not print black.
Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
  • 63 Answers
SOURCE: can't print to a Epson STYLUS SX510W from MacBook
First make sure the Wifi light on the printer is lit which will show if the printer is connected wirelessly to the router or not. If not then enter the Network settings on the printer and carry out a Wireless Lan set up using the wizard.If there is now a light Go to Apple Menu > system Preferences > print and fax, Delete the printer that is in the list and then select Add. Select Bonjour and wait for the printer to appear, highlight it and then add it.
Posted on Feb 10, 2010
MUKHTAR
  • 2022 Answers
SOURCE: printer offline on wireless home network
first make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 20, 2010
Printer offline
try to go in and mark the printer as online and the printer should come up as in ready state
Mar 16, 2014 | Epson NX625 AllInOne InkJet Printer
Offline
Any number of things that could be causing this but things to try.
  1. Try plugging the printer into a new USB port (assuming you're using USB for connectivity
  2. Try a different connection cable
  3. Check the printer has not been accidentally marked as "Use offline" (WinXP: Right click on the printer icon and look for the relevant line)
  4. Check some joker hasn't set the "Printer Properties" > "Availability" time to limit access
  5. Check the Print Spooler service is running for your computer
Those are all reasonably common issues but usually it comes down to the cable or an OS setting.
Hope that helps, albeit a bit later than you'd hoped.
Jun 23, 2013 | Epson Stylus Photo R300 InkJet Printer
How to set up my espson cx8400 printer to be a wireless printer
your printer should have come with a cd to help you make a wireless connection between them
Apr 14, 2013 | Epson Stylus CX4800 All-In-One InkJet...
Printer says it's offline. Won't print. Please help.
go to control panel and devices and printers right click on epson you will get the option of use printer online, select that it would work
Sep 07, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
Cannot scan or print with epson stylus cx5900, working with mac os x version 10.5.8 even though already download driver update from epson website. when printing, error show printer is offline. when...
Try uninstalling, then installing the driver fresh. NOT an update. You could also have a bad printer cable, borrow one from a friend. No sense buying one as almost all new printers come with one!
Nov 02, 2017 | Epson STYLUS CX5900 Printer
I cant get the WLAN on my epson stylus PHOTO TX810FW to turn on or either connect through WI-FI to my two laptops.
make sure in your wifi router dhcp is enabeld and you select the ip auto in printer.
Thanks.
Have a good day
Dec 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Macbook and printer problem
Try a different USB cable if plugged that way, or if you have a USB hub, bypass hub an connect direct
Mar 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo R340 Printer & MacBook Pro
I try to istall my epson stylus photo R340, but i dont have the disk.what can i do?
Aug 03, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
