Question about Maytag EPIC MFW9700S Front Load Washer
F-h is the problem magtag neptune front load
Washer wont work
    President:
  • Maytag Master
  • 2,651 Answers
Fh is a NO WATER fault, check your incoming water supply, watch out some new stainless steel inlet hoses marked" floodsafe" are imfamous for shutting water supply, if you have these hoses i strongly reccomned replacing with "NORMAL stainless steel inlets" FLOOD SAFE brand no good
Posted on Jan 25, 2009
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
I want to place wet clothes in the washer and just spin them without washing them
sounds like you have a door lock problem, maybe the wax motor is not working properly of the spin switch is bad. You may have a problem with the motor controller also. Kind of hard to tell you how to trouble shoot on internet, unless you just want to replace parts till it works, call for service.
Apr 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washer when on spin make a very lould noise. like maybe a bearing is out it is a magtag neptune front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Maytag Dryers
HAVING AN ERROR CODE (OP) ON MY WASHER TOP LOAD MAGTAG NEPTUNE, WHAT SHOULD I DO?
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
I discuss the troubleshooting the Left Hand Lid Lock in that sticky.
I can't find my repair notes on this forum no Sticky and no Service Manual.......D*ick
Feb 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
