Question about Canon PIXMA iP1600 Printer
I'm trying to install my color ink for my canon ip1700 printer but i don't know how
  • Anonymous Feb 26, 2009
    how do you install the ink cartridges
    President:
  • 2,692 Answers
Just run the install disk. If you do not have the disk download the driver (and manual) from you CANON support web site below:   If you have Xp.Hook up the printer, turn it on.  GO to  START- CONTROL PANEL - PRINTERS AND FAXS - ADD A PRINTER. When it asks if you have the disk sayno. Tell it where you have put the driver file,( I usually put mine straight on the hard drive c:) when asked.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=13364
Posted on Jan 21, 2009
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Why I can't print in black and white.
It may want the cartridge in to protect the heads. Put an old empty on in. Make sure to go to Start, Settings, Printers. Select the Pixma and go to Printing Preferences. Once here set the COLOR OPTIONS to Grayscale, print black ink only.
Hope this workds for you.
good luck
Feb 19, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
INSTALLATION OF CANON IP1700 PRINTER
I dont have a cd to install my Canon pixma iP1700 printer. Can u please help me. Thanks
iP1700
Aug 10, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Pixma1700
The printer may need servicing, the printer ribbon like cable with the ink tubes in could be blocked by old dry ink.
Mar 31, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Free canon ip1700 software
hi sir i need free canon ip1700 software to install my pc plz help me
Feb 16, 2008 | Canon PIXMA iP1600 Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
49 people viewed this question
old marine
old marine
