Machine failing to drain
There is a noise coming from right lower back corner of machine where drains water. Machine failed to drain, I isolated the problem to the small white fan like part in hose system. doesn;t seem to be grabbing properly,
  • Washing Mach... Master
  • 3,463 Answers
From your description, I would say that the pump impellor is slipping, and the only solution would be to fit a new pump.
Plz rate my suddestion.
Thankyou.
Posted on Jan 21, 2009
Water not draining from machine
You either have a clogged or jammed up drain pump or a failed drain pump. p/n WH23X10030
IF the machine is full of water, drain the washer, remove power, remove the front cover of the washer by using a putty knife and pushing in between the top and front at the front corners about 3 inches in on both sides. The pump is on the lower right side. remove the pump from the washer, remove the 3 screws holding the pump motor to the body and remove anything that may be jammed in it. IF there is nothing in it, replace the pump assembly.
Apr 06, 2014 | GE GTWN3000MWS Washer
My daughters washing machine of 3 yrs old keeps stopping and flashes F 18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine..
Open flap at the bottom righthand flap.
Keep big bucket handy for water.
Remove clear plastic attached to black tube (slowly)
This will empty water from washing machine.
Once empty - no water coming out from washing machine then open big opener next to tube and remove any objects inside( coins, buttons and such)
Put back clear plastic filler firmly inside as before.
Close big opener next to tube.
close flap
Turn machine programe knob to DRAIN.
Start washing machine.
Should do the trick....
Good luck
Apr 01, 2011 | Washing Machines
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
WATER IS NOT DRAINING
Most likely the pump has failed or is blocked or jammed. Coins and buttons become trapped in the impeller. Suggest you check the pump drain inspection point - there is always one somewhere at the bottom of the machine. See if you can rotate the pump motor - ISOLATE THE POWER FIRST!
Apr 01, 2008 | Washing Machines
Aftron Washing Machine draining power
check and see that the entire drain line is free from any obstructions, if you have lowered the hose and still not draining entirely, its a sure sign of obstruction somewhere in the drain line or even the drain pump.
Jan 27, 2008 | Washing Machines
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
