Question about Amana Refrigerators
Ice build up in freezer
Amana refrigerator model #ABB2524DEW 25 cu ft. the bottom freezer frozen solid with ice build up and the refrigerator compartment does not seem cold enough. Adjusting the tempature contol does not help.
Thermostat problem? please help. thanks.
  • okaren126 Jan 21, 2009
    THANKS so so much. Can you advise further how I determine which part needs replacement; the defrost timer, heater, or therma disk? I thought it was the thermostat, could that also be a possibility? Your help is so so appreciated.
  • 161 Answers
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • Ron Buice
    Ron Buice Jan 21, 2009
    Thermostat would make it run more and freeze items in the ref. side and not likely to Ice/frost build up in the freezer.
    The defrost system failure more likely.
    They will have to be checked with an OHM meter. The heater and therma disc are on the cooling coils in the freezer.
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
No air flow in fridge compartment,rfeezer working but not as well as normal
you may have ice build up at the freezer section. kindly look at the back side of the freezer if you have ice build up.
if you do then you have problem with defrosting.
tnx 4 using fixya,
Sep 20, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana SRD522
sounds like water line is blocked with frozen ice. have a technician clean the line and check the icemaker and water line for any kinks.
Jul 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not that cold
check to see if the evap. fan is running or if you have frost build-up on the back wall of the freezer. if so call a service company quick because the freshfood section is not cooling either; all the cooling starts in the freezer and transfer air via evap fan to the freshfood section. am are more subject to defrost t-stats going bad
Jun 03, 2008 | Amana Easy Reach 19.7 cu. ft. Cabinet...
Refrigerators Logo
846 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
