Question about ASUS Eee PC 900 Notebook
Doesnt switch on
When i switch on my eee pc 900, it comes up with teh windows xp screen and then goes blank with a little line running through the middle of the screen. can u help me that
  • rambo9000 Jan 29, 2009
    I've got linux on my asus eee 900, and i left it on this afternoon and the screen went black after a while (screensaver) and now I can't turn it on anymore. With battery (with and without net-power), with net-power without battery, nothing happens when I press the powerbutton.
    Only those four lights on the front react, when I turn the computer 'on' they all flick on, when I turn it 'off' they all go off, when I remove the battery it is indicated and same with the power-supply.
    But for the rest: nada, no response. Not even a little sound.
    And I didn't even transport it, it just stood still on my desk!
  • evoultep Feb 03, 2009
    I just got my eee pc 900 a few days ago and the same thing happened to me this morning. I started the notebook up and a screen came up "system starting". After that there was nothing except for a little line in the top right corner popping up now and again. When I would turn off the computer by holding down the power button a screen comes up "system shutting down". I don't what to do!
Does Eee PC 900 has an on-screen keyboard?
Windows should have the feature. Check Start menu, Accessibility, or something along those lines. Otherwise it may be in Control Panel, do a search for accessibility.
Oct 22, 2012 | ASUS Eee PC 900 PC Notebook
I have an asus eee pc 900 notebook, my daughter has pushed something & now when turned on displays the windows xp loading screen, then displays a page that explains windows did not start successfully I...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule when you restart then defragment your hard drive
hope this helps
Jan 12, 2011 | ASUS Eee PC 900 Notebook
I want to reboot my asus eee pc 900 and i dont
hi
what do u mean by reboot
if you want to re install windows then you have to run from the dos
just put your windows CD on your opticle drive then run that cd on dos mode
and folow the steps what ever come on screen
May 16, 2010 | ASUS Eee PC 900 PC Notebook
Asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
Aug 29, 2009 | ASUS Eee PC 900 16G Notebook
Bought 3 Eee PC 900/XPs. Bought recommended Crucial 2GB SODIMMS to upgrade memory for all three machines. After upgrade and just after Windows XP loads the screen goes crazy. Crucial suggested...
pop battery out ...... re-start with cord power , then shut down completely. pop battery back in after 5 minutes .....and try that ......you may also want to check your power settings .
Jul 13, 2009 | ASUS Eee PC 900 PC Notebook
Eee pc 900 XP wont enter the windows menu
ok first thing is to calm down and wipe out the computer.It seems you have a windows crash and re-installing a fresh copy should solve this problem.If you do not have one then go on google and search for ubuntu 9.04, download and put on a cd and put cd in pc and install new open source o/s.Its free and requires no licence nor any need to buy anything, unless you have a license copy of windows.
Jul 02, 2009 | ASUS Eee PC 900 16G Notebook
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
My asus pc eee 900 does not enter the windows
Go in the BIOS and in Advanced Make you CD-drive the first boot device. Put in your Windows CD and reboot. It wil display. Press any key to boot from CD. Press Enter. You wil come to a screen that ask if you whant to repair. Take that Option. Your Boot sector may be faulty.
Mar 13, 2009 | ASUS Eee PC 900 Notebook
When i switch on my eeepc 900 it just comes up with the windows xp screen and then it just comes up with a blenkscreen with a line running through the middle of the screen. what do i do?
All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
Jan 21, 2009 | ASUS Eee PC 900 Notebook
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee PC 900 Notebook Logo
155 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
