Question about Yamaha Audio Players & Recorders
Yamaha htr 5900 code for time warner cable - Yamaha Audio Players & Recorders
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 50 Answers
SOURCE: All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Posted on Jul 05, 2009
  • 40 Answers
SOURCE: problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Posted on Jul 25, 2009
SOURCE: My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Posted on Aug 21, 2009
How can I lock my Input Mode setting?
sounds like you have too much hooked up trying to do the same thing and are fighting each other .
May 12, 2015 | Yamaha Audio Players & Recorders
Tip
I need a config. my remote control UEI By DirecTV
<span>If you are using the universal remote control provided by directv, try these codes 10054, 10030, 10171 <br />OR:<br /><b>Satellite TV Systems</b> Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 <b>Cable TV Systems</b> Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610 For the LTxxxxx series: You can use the codes listed under RCA, LG, Philips or Yamaha. <br />Thanks</span>
on May 07, 2011 | Televison & Video
Need remote code for yamaha yhts401bl receiver
The remote (most of them in fact) have only about 50 possible codes built into them. Either research for another remote or stick with the original one for the receiver--been there and done that myself.
Apr 29, 2012 | Yamaha YHTS401BL Virtual Surround Speaker...
Problem with sp cable (yamaha)
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Dell 32" HD TV flashes black every few minutes
You may want to make sure it's a Yamaha by seeing how the TV displays when connected directly to a cable box or DVD. Also try different HDMI or component inputs to see if it's something in the input connection you're using.
Apr 27, 2017 | Sharp Aquos LC-32D40U Television
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Cable company remote cannot find Yamaha HTR-6130
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Programming manufacturing code
I'm trying to figure out the same thing, so if you ever figure it please let me know, I will do the same. thanks.
Jul 21, 2008 | Yamaha HTR-5740 Receiver
26 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
