Question about Hoover Washing Machines
HOTPOINT VHD146A STOPPED. CYCLE 59'. 1200RPM AND STAIN BLASTER LIGHTS FLASHING
FLASHING X 5 TIMES
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
SOURCE: I have a Hotpoint aquarius WMF540 washing machine
f01 RELATES TO A MOTOR PROBLEM , POSSIBLE CONTROL MODULE COULD CAUSE F01 TOO.
TRY THIS FIRST, " reset it : hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesn't always work 1st time so keep trying, good luck" If not then try the proceedure below.
unplugged the washer power supply, closed the water
- unscrewed two screws that hold the control panel
- removed the panel - you need the lid to be semi-opened
- (re-conected all connectors to fix any possible oxidation or unpluging - then tried the washer, but problem persisted)
- unscrewed all screws that hold the side cover - only the right one had actually been necessary (when standing in front of the washer)
- unscrewed all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrewed two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver I've cleaned the contact together with the connector and tried the washer - still no effect
- cleaned the black wire connection with the same way
- tried the washer (spinning program) and - voila! It works!
- tried unplugging the black wire and running the spinning program - both the motor AND the pump didn't start
So, it looks to me that the problem was in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor, that caused insufficient voltage and thus a power for the motor but probably still enough for the pump. The randomness of the problem was probably caused by humidity in the room and maybe some more factors - the washer is actually opened from the bottom so when I test the washer more times and see this as a solution, I'll probably cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside. It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer. It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Service manual, generic, to help troubleshoot.
Posted on May 21, 2010
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMF940 Washing machine -
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
WWW.HOTPOINTSERVICE.CO.UK
Posted on Jan 03, 2011
KevinWhite
  • 1902 Answers
SOURCE: my candy alise washer dryer
Hello & Welcome to FixYa
The problem is with the door lock-switch assembly not working, the unit detects that the door is not closed/locked and so will stop in middle of cycle. Please get back to me if you have any other questions.
Kevin
Posted on Jan 09, 2011
Daniel S
  • 4323 Answers
SOURCE: HOOVER NEXTRA Although this machine is
Hi
The issue seems to be with bad door lock-latch assembly and should be replaced. You can try to clean the latch mechanism and also blow air with help of hair dryer to see if it works....if it won't work then it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 11, 2011
I have a candy alise gow475, it starts up a cycle but stops whenever the drum should start to turn
motor speed sensor problem u cant fix yourself .it needs a skilled technitian.
Mar 30, 2015 | Candy Washing Machines
Candy Alise-the stain blaster and 90 degree lights are flashing and it will not function. Please help!
Hi again,
11 flashes decodes as 'faulty dryer module or wiring to it'. Not sure that helps you other than saying that a service call is required, sorry ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Candy GrandO 8kg Erratic Cycle Selection and Flashing Lights
I can't solve this problem but have exactly same problem with erratic lights. I 'm starting to worry about possible explosion.
Mar 12, 2010 | Candy Washing Machines
Flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Aug 04, 2009 | Refrigerators
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Flashing Lights
this error code is time out draining, check for a blockage
Jun 05, 2007 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Washing Machines Logo
127 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
