Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE pss26ng artica freezing fresh foods - GE (PSS26MSRSS) Side by Side Refrigerator
jumptrout51
  • 3361 Answers
SOURCE: GE Artica SxS Model #PSS25NGMD: Food on fridge
So long as the fresh food side stays 36-42 degrees you are OK.
Posted on Feb 22, 2009
sncdoc
  • 3 Answers
SOURCE: GE PROFILE FRIG PSS26PSTASS
The recall reads (in part):
GE Consumer & Industrial places a very high priority on product quality and customer satisfaction and thus continuously assesses our product reliability. Recent analysis has discovered a potential problem with the main circuit board on a limited number of refrigerator models, which could lead to lower than anticipated life expectancy on that component. Therefore, if the main circuit board fails, GE Consumer & Industrial will replace this part free of charge to the consumer until further notice.
The models affected are side-by-side plastic liner, side-by-side metal liner, bottom freezer two door and bottom freezer French door. The models were produced between May 2005 and August 2006 (HH – RL serial range) and are included in this program.
Potential Additional Covered Parts:
Specific parts involving the failure of the main board are included in this program. These parts are limited to the following:
-Evaporator Fan failure, only if accompanied by a Main Board failure
-Dispenser Board failure, only if accompanied by a Main Board failure
Posted on Apr 18, 2009
  • 323 Answers
SOURCE: vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
Posted on May 14, 2009
SOURCE: GE profile side by side is freezing fresh food and
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
Posted on May 02, 2010
fixyourboard
  • 310 Answers
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Posted on Jun 22, 2010
Ge gss25wgmd fresh food freezing
You will need to perform a refrigerator self diagnostic test found in the service manual found here=> GSS25WGMD Service Manual
Then go to page 48 of the service manual (Damper Door Not Opening or Not Closing) GE ARTICA PROFILE TECHNICAL INFORMATION This test will help you determine if the problem is the damper, temperature sensor or the control board. Doing these test are not for everyone and may require that you have someone that can perform diagnostics. If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | GE GSH22JFR Side by Side Refrigerator
Ge side by side profile Artica, the bottom drawer on the fridg side keeps running and freezing everything. I can't seem to shut it off. Please help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile Artica S/S, model # PSS25NGMD BB. The fridge side is freezing the food and the digital thermometer keeps going back to 22-25 degrees. Also, yesterday the in-door water dispenser quit...
With temperatures like that the water tank is frozen stopping water to dispenser. This could be thermistors in fresh food section going bad or a combination of thermistors and motherboard. I can assist you if you have not already called for a technician. Sea Breeze
Mar 23, 2010 | GE Refrigerators
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
