Question about Crafts & Hobbies
What starters paint set should I get? - Crafts & Hobbies
    New Friend:
    Problem Solver:
  • 7 Answers
The most recommended colors for starters are red, blue, yellow, white, black, brown, green, orange and purple. You will also want to purchase stiff bristled brushes for painting and a palette of your choice.
Posted on Jan 10, 2013
Can you paint gourds which are not dry inside
You can only paint gourds when it is dry inside.
Use acrylic paint and it dries very fast. Click:
Reeves Complete Acrylic Painting Set
Jan 12, 2015 | Tools & Hardware - Others
What is watercolor?
Watercolor paint sets are similar to oil paint sets, but instead of oils they are stocked with watercolor paint. Grade schools and middle schools students use them often because they are not toxic and are very safe for children to touch, paint with and use in general.
Feb 03, 2013 | Crafts & Hobbies
Trouble starting after clutch/flywheel replacement
if starter does'nt turn over or only sometimes turns over the problem is the bolts that hold starter in there is something covering them (Sealant,Oil,Grease,Paint) the bottom of these bolts must be bare metal to provide A good ground for starter a quick ck of this to confim can be done with a jumper cable one end of cable on battery negative term and other to back cover of starter (scrape paint) do not let it hit starter power wire (red) turnn key if it works correctly you know you have a bad ground
bad engine grounds can also affect dash gauges from providing a believable reading and also electronic engine mgmt controlls
Apr 18, 2012 | 2006 Dodge Ram 2500
1979 XLS Sportster won't start, I took all the
The thing that looks like a small solenoid on the bottom of the oil tank is the starter relay. It has three terminals on it. One terminal should be red wire and should have battery voltage on it when you turn the switch on. One wire should come from the start button and the other should go to the small terminal on the starter solenoid. Contact me directly at wd4ity@bellsouth.net. I'll send you a schematic that shows how it's supposed to be wired. Look on the solenoid and see if you see some small numbers around each of the electrical connections. Also, the bolts that hold the relay on act as a ground. If you had the oil tank painted, you may not have a good ground connection on it.
Good Luck
Steve
Jun 08, 2011 | 1979 Harley Davidson XLS 1000
How do you change an ignition switch on a 2002 VW beetle
This is for the requested item:
Removal & Installation
  1. If necessary, make sure you have the radio code.
  2. Place the steering wheel in the center (wheels straight ahead) position.
  3. Disarm the SRS system, as outlined in the Chassis Electrical System.
  4. Make sure the negative battery cable is disconnected.
  5. Remove the steering wheel, as outlined in this section.
  6. Remove the upper and lower steering column switch trim. Refer to the Turn Signal (Combination) Switch or Multi-function switch procedure for details.
  7. Disconnect the multi-pin connector from the ignition/starter switch.
  8. Remove the locking fluid (paint) from threaded holes of screws.
  9. Loosen the two screws slightly, and pull ignition/starter switch out from steering lock housing in direction shown.
Remove the locking fluid (paint) from threaded holes of the screws (A). Loosen the two screws (A) slightly, then pull the ignition/starter switch out from steering lock housing in direction of the arrow
To install:
  1. Push the ignition/starter switch into steering lock housing.
    NOTE When installing the ignition/starter lock switch ensure that the ignition/starter lock switch and the lock cylinder are in the same position, e.g. "ignition on".
  2. Tighten screws and seal securing holes with sealant D2.
  3. Connect multi-pin connector to ignition/starter switch.
  4. Install steering column switches, steering wheel trim and steering wheel, as outlined in this section.
Mar 06, 2010 | 2003 Volkswagen New Beetle Convertible
Solenoid just clicks and starter doesn't engage.We removed engine to paint frame started worked then but when we reinstalled engine starter doesn't engage.Starter motor was checked and was good.There is a...
Does your starter have a good ground now after the paint job??? If you jump from the battery to the starter side of the solenoid, do you get any results?
If you have good power and the starter is known good, your solenoid could be faulty.
Thanks for your question at FixYa.com
Jan 09, 2010 | 1987 Suzuki LS 650 Savage
1996 jeep cherokee sport starter
disconnect the battery, negative side first.
remove both positive wires from the starter.
remove the bolts from the starter.
install new starter.
make sure positive starter wires are free of corrosion and rust, use sand paper or a file.
tighten positive wires just snug, then another 1/4 turn, ** not too tight or you will snap the stud off the starter solenoid**.
coat wire ends and starter studs with die-electric grease, battery protector, spray paint , or something non metalic.
connect vehice battery, negative side last.
May 18, 2009 | 1996 Jeep Grand Cherokee
Total Novice
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Feb 01, 2009 | Badger Basket Starter Spray Gun Hobby Set
Crafts & Hobbies Logo
452 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
