Question about KitchenAid Refrigerators
Where is the ice and water filter on the KitchenAid KSRX25F
aborcass
  • 2651 Answers
SOURCE: Kitchenaid refrigerator dispenser not working
possible bad switch, but that would only control onr of the features, sounds like your have an power supply issue to the entire door assy , check the incoming waire s eiterh on top or bottom of door hinge, look for broken/unplugged wire harness
Posted on Apr 07, 2008
  • 330 Answers
SOURCE: In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Posted on Jul 02, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
odiebugs
  • 949 Answers
SOURCE: kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Posted on Mar 27, 2009
  • 68 Answers
SOURCE: changed filter water leaking out of ice maker even when shut off
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
Posted on May 02, 2009
Kitchenaid preserva is leaking water around light closest to the filter when you get water from the door and when the ice maker fills
Check your filter for cracks with filter out and check water lines where they connect to the filter assembly. Something is cracked or you have a pinhole in one of the water lines.
APPLIANCE 911
Nov 17, 2015 | KitchenAid Refrigerators
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
No water to ice maker or water dispenser
You have a bad water valve . It needs to be replaced.
Jan 23, 2010 | KitchenAid Architect® II KBFS20ETSS...
No water or ice dispenses
replace water filter in the back of fridge
Jan 09, 2010 | KitchenAid KSSS36QK Side by Side...
Changed filter water leaking out of ice maker even when shut off
Apr 28, 2009 | KitchenAid Superba KSRG25FK Side by Side...
I have a Kitchenaid Superba and when ever we turn on the ice maker. it says our filter needs to ebe changed. is that a problem? However before even when the filter was bad it still made ice. whats wrong?
Most refrigerators with filters will not work...with a bad filter...they will work initially ...for a while after the filter indicates it needs to be changed but over time the filter can become completely clogged...and no water will flow...also the impurities that were being filtered out...are now in the water and the ice and can accumulate in the ice tray...or at the spot where water is dispensed into the tray...with real hard water calcium can build up and inhibit water flow. I would definitely change the filter..... I had the same problem and the filter and the monitor for the filter are tied into the circuitry...so yes it can definitely stop the water flow.
I hope this helps....good luck...please rate me...The Fang
Mar 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
52 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
