Question about Electrolux Epic 6500 Vacuum
Electrolux parts diagrams for epic 6500sr model C102A
I NEED PARTS DIAGRAMS FOR THE EPIC sERIES 6500sr VACUM CLEANER
  • 15 Answers
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Posted on Apr 09, 2008
  • 61 Answers
SOURCE: electrolux vacuum epic 6500sr how to change filter ?
It has 1 or 2 clips on each side simply push in on each side firmly and pull up. Note: it may be reaaly stiff just muscle it a little.
Posted on Apr 15, 2009
  • 70 Answers
SOURCE: I have an epic 6500SR I'm trying to change the
You really don't want to get into the vacuum. You could cause more damage than what you have now. After you do get into the vac, the cordwinder is another monster to get into.
There are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. After you get the locking strips out, turn the vac over and pull the bottom off. Then you can see the cordwinder.
The best thing to do is take the vac to a Aerus/Electrolux shop for repair.
Posted on Nov 03, 2009
  • 70 Answers
SOURCE: I have an Electrolux Vacuum Cleaner. It is an
The OEM part number is 45853 if you go to the Aerus/Electrolux store. Other vacuum shops should have the part. it fits other brands.
Joe
Posted on Nov 16, 2009
pappapumpdaf
  • 635 Answers
SOURCE: My epic 6500SR is not working. The power comes on
This is usually caused by your full bag indicator shutoff switch.
The control valve has gone bad. This is the dial on the top of the vacuum that has numbers on it.
You cannot bypass this problem from outside the machine.
The part can be bought at the local outlet. Go to www.aerusonline.com and find A local dealer. It is not too expensive to fix, and is a common problem on later model electroux vacuums.
Posted on Mar 15, 2010
Where is the CVA located in the Electrolux Epic 6500SR?
You need to replace the control valve. It's inside the canister under the dirt cup. If you want it done by a professional, call your local authorized Aeurus dealer.
Jun 28, 2015 | Electrolux Vacuums
Need manual for epic series 6500sr
Go to aerusonline.com. They have a section under the "surface" heading that you can download the manual. If no Epic 6500 is showing, use the Legacy manual. Same thing.
Hope that helps. :-)
May 13, 2014 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
Mar 15, 2010 | Electrolux Epic 6500 Vacuum
Nov 02, 2009 | Electrolux Lux 5500 Canister Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Electrolux vacuum epic 6500sr how to change filter ?
Apr 10, 2009 | Electrolux Epic 6500 Vacuum
Vacum keeps turning off with warning lights
Actually the problem is that you need to change your control valve. The motor has an internal thermostat on it already so the chances of you burning the motor out are very slim. By changing the control valve, you will solve your problem. Very simple and quick fix.
Sep 22, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
281 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
