Question about Microsoft Xbox 360 Console
Missing part affecting RF module and led.
Can i replace the part labelled 12ebavn5 (with something else, if not how to hardwire controllers
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
Own Atari 2600. Atari not responding to television. (FUZZY SCREEN) One of three problems: 1. I AM NOT CONNECTING SYSTEM CORRECTLY TO TV. please instruct me how. parts i have are: Radio...
Hello!
When powering the stuff there should be light indicated that there is a power on it. how ever if these not been observed, power adapter maybe busted. try to fix it or replace it. Please refer to the atari manual for the correct operation of your stuff.
hpe this help,
melnavz
Mar 14, 2008 | Video Game Consoles & Games
NES controller input
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Mar 02, 2012 | Nintendo NES Console
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
Jan 13, 2012 | Nintendo Super NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Installation Steps:
Nov 25, 2011 | Nintendo Super NES Console
Eu tava com o super nintendo ligado e ele espludiu a fonte
Aug 21, 2011 | Nintendo Super NES Console
I dont understand how to plug the gamecube into the televison or the dvd player?
Quick Tip! If your system is connected using AV cables or the Component Video cable and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
If this is your first time connecting your system, we strongly suggest you verify your hookup before continuing with the blank screen troubleshooting.
Are you using any accessories that didn't come with your system? Unlicensed products are not fully compatible and may not work correctly.
With the power ON, open the Disc Cover, remove the Game Disc, close the Disc Cover and turn the power OFF and then ON. If the Main Menu appears, your disc may be damaged or dirty.
Check your system connections and ensure they are all firm and correct:
Stereo AV cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input. Also ensure that your audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
Component Video Cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the green plug into the green input (labeled Y), the blue plug in the input (labeled Pb or Cb) and the red plug into the red input (labeled Pr or Cr). Ensure that your audio plugs (red and white from the Stereo AV cable) are plugged into the audio input jacks associated with the component input jacks and that the yellow plug is hanging, and not plugged in.
Check to see if the game you are playing is set to progressive scan mode. If it is, try changing it to interlace mode. To do this, load the game disc into the system and hold down the B Button of the controller while turning on the system.
RF Switch/Modulator
Try switching both the TV and modulator to either channel 3 or 4. Also, try disconnecting the antenna from the RF Switch.
Common Solution: For RF connections, we find that video problems occur most often when an unlicensed RF switch and modulator set are used. Make sure your RF switch and modulator set are two different pieces and the name "Nintendo" is molded onto the RF switch and modulator. If your RF modulator is one piece or is black and it says "for use with Nintendo" it is an unlicensed product. Unlicensed products are not fully compatible with our systems and may not work correctly.
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position, while the Control Deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the Control Deck.
Move your Control Deck farther away from your TV. If the Control Deck is too close to the TV, the Control Deck may cause some interference.
If you're using the AV cables or Component Video Cables, verify that your TV or VCR is on the correct the input select.
If your TV has a closed captioning option, make sure that it's turned off.
Check the game manual to see if the game has any special features that might appear as a problem.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If these steps do not resolve the symptoms you are experiencing with your system, check out our convenient repair options.
Nov 27, 2010 | Nintendo GameCube Console
NES system doesnt work with my t.v.'s. i have plasma samsung and a symphonic 20" older t.v. that it doesnt work on either can you tell me what to do?
NES to TV Hookup
Installation Steps:
Aug 06, 2010 | Nintendo NES Console
Need to know how to hook up the dinosaur nintendo
Installation Steps:
Jun 05, 2010 | Nintendo NES Console
Controllers
Replace the batteries (or charge the batteries if rechargable.) Also make sure nothing like a cordless phone, WiFi base station nor microwave is nearby. They'll cause interference with the wireless controllers.
Dec 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
304 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
