Ricoh Aficio MP C5000 SC543 - Office Equipment & Supplies
  • 58 Answers
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 13, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: Aficio 180 Functiobnal problem SC543
SC546 Fuser temp. not steady falls or increases 10 durring standby.
Reset fuser and some other error codes by Enter SP 5-810 and select 1 press and hold photomode key while
holding photomode key press (#) key
Posted on Jan 29, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
SOURCE: SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Posted on Sep 02, 2009
How to clear memory in a mp c5000 macine
There are many counters in this machine. Jam, Error, Feed, All, Memory, Service Codes etc, that are located in the service software of the machine. If you don't know what each one does you can end up doing more harm than good by wiping out the wrong ones. Best to call a trained tech.
Aug 14, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Aficio mp c5000 sc 202
debe cambiar el motor poligonal de la unidad de laser
Sep 20, 2013 | Ricoh Aficio MP-C4000
Ricoh MP C5000 can't scan to gmail
once again the tech boyz mix up the formula ssl is a device unique identifier technology which has many permutations i'd expect it will take an act of God to get gmail apps to do this for a single device, and Ricoh is not in that business
keep an eye on the gmail apps forums and you might get lucky
May 29, 2012 | Ricoh Aficio MP-C5000
How to delete an email address on the ricoh aticio mp c5000?
Go to system tools. Admistration tools. manage addresses. select delete then the address you choose to delete.
Nov 29, 2010 | Ricoh Aficio GX5050 GelSprinter InkJet
Tengo na Impresora Ricoh Aficio 250 y me aparece en pantalla (PROBLEMA SC543) y no me Copias Sacar vu. les agradeceria me ayuudaran Con Este Problema
SC543 is caused by a defective Fusing thermistor. check or replace both center and end thermistor this will solve your problem
Nov 25, 2010 | Ricoh Aficio 250 Copier
Check the meter on a Ricoh MPC5000
On an MP C5000, press the User Tools button on the operation panel, then on the touch screen press Counter.
You'll see the various totals for copying and printing, and it will be broken up for color and black & white. If you want to print out a sheet with all of the meters on it, just press Print Counter and then hit the green Start button.
Jul 06, 2010 | Ricoh Aficio AP3200 Laser Printer
I am looking for a walk up driver for a ricoh Aficio MP c5000
please go to your aficio MP c5000's website and download it then install it.
Aug 10, 2009 | Computers & Internet
46 people viewed this question
jasbo
jasbo
