Question about Dell Computers & Internet
How do I reattach the cord between my screen and keyboard?
My computer is fine when it is just sitting -- but when I move it -- the screen is loose and when it moves it goes completely white -- I want to know how to attach the cord running between the two so that there is no longer a connection problem
  • Dell Master
  • 32,281 Answers
The ribbon cable may need the connected reattached to the motherboard. It could be possible this video ribbon cable is faulty and then this ribbon cable needs replacing.
Posted on Jan 10, 2013
vrabhilash
  • 52 Answers
SOURCE: Screen flashes and goes black when you move mouse
some virus or spyware would have been the cause for tat...
go to start and then run,
there, type msconfig n press enter
in tat msconfig window, try clicking startup tab, there, try to remove tat virus startup, which would have been the cause for ur problem..
after tat restart and check, if it is solved
Posted on Jul 20, 2008
  • 395 Answers
SOURCE: open the computer
The Hardware Maintenance Manual for the - ThinkPad T40, T40p, T41, T41p, T42, T42p can be found on the lenovo web site at
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46464
or
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/39t6192_01.pdf
The document requires adobe reader thats available for free at www.adobe.com
Posted on Nov 26, 2008
lafalot
  • 152 Answers
SOURCE: DAMAGED POWER OUTLET ON MY LAPTOP
First, you do not need to replace the motherboard. What you are describing is a very common problem for HP notebooks. You can buy the part on eBay for about $5.00, usually with shipping! It will take a while to take the machine apart - and you must be very careful! but it's an easy fix once you get the notebook apart. This page: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=214342& will give you the info on your machine. Just download the manual entitled: Maintenance and Service Guide. You will need Adobe Acrobat to read the file. I recommend that you print the guide before you begin. It will walk you step-by-step on how to disassemble the notebook to get to the power jack. It all requires is some soldering. You may not even need a new jack, but just know that eBay sellers have them.
Please remember to rate my solutions! Thanks
Posted on Feb 05, 2009
geminii_lady
  • 87 Answers
SOURCE: the display screen goes off when the laptop is moved
Sounds like the ribbon which runs between the screen and base is being nipped or is not making a good connection. This is a common problem. If that is the problem you may find that by adjusting the screen you can actually get the picture to show again which will confirm but obviously it will continue to happen.
Most laptops have a narrow panel above the F keys which snaps off and reveals the ribbon underneath. Check the connection is pushed in tight and also that the ribbon isn't being nipped, reposition to stop this happening. If it's been damaged then obviously you will have to replace it.
Posted on May 18, 2009
birky09
  • 104 Answers
SOURCE: Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Posted on Dec 01, 2009
Testimonial: "Thanks for the quick reply. Your advice worked brilliantly and now fully functioning laptop is back. "
I installed a vga cord and a audio cord from my dell computer to the tv but nothing happens
Are the cords (cables) in good condition? Will they work in other situations? You may need to make adjustments in the computer control panel.
May 07, 2015 | Dell Computers & Internet
Front panel cords
1.
If your computer beeps when you start it but does not display anything on your monitor:
a. Disconnect and reconnect your monitor from your computer.
b. Verify that your monitor's power cord is connected and that your monitor is turned on.
c. If possible, connect your monitor to a different computer to make sure that your monitor works properly.
d.If your monitor works but your computer beeps and displays nothing,your video adapter has probably failed. If your computer is underwarranty, contact your computer manufacturer for support. If yourcomputer is not under warranty, and you are comfortable opening yourcomputer's case and replacing internal hardware, purchase and installa compatible replacement video adapter. Otherwise, contact a servicecenter for assistance. While replacing a part is a nuisance and may becostly, your documents, pictures, and e-mail should be safe and will beavailable when your computer is fixed.
2.
Ifyou see an error message that indicates that a keyboard is not presentor a key is stuck, turn off your computer and reconnect your keyboard.If the problem continues, replace your keyboard.
3.
Sometimesyour computer won't start because your computer is not compatible witha hardware accessory. If you have recently added a new hardwareaccessory, turn your computer off, remove the accessory, and restartyour computer.
4.
Removeall hardware accessories except your keyboard, mouse, and monitor. Ifyour computer starts successfully, shut down Windows, turn off yourcomputer, and add one hardware accessory. Then, restart your computer.If your computer fails to start, the hardware accessory you mostrecently added is causing a problem. Remove the hardware and contactthe hardware vendor for support. You can reconnect other hardwareaccessories.
5.
Youmay have a loose connector. Turn off your computer, remove allconnectors from the outside of your computer, and then carefully pushthe connectors back in. Look for stray wires, bent pins, and looselyfitting connectors.
6.
Ifyou are comfortable opening your computer's case, shut down yourcomputer, unplug the power, and open your computer’s case. Remove andreconnect all cables. Remove and reconnect all cards inside yourcomputer, including your computer’s memory chips. Reassemble yourcomputer before attempting to start it again.
7.
If your computer still doesn't start, your motherboard, processor, memory, or graphics card may have developed a problem. Contact technical supportfor further troubleshooting assistance. While failed hardware can befrustrating, your documents, pictures, and e-mail should be safe andwill be there when your computer is fixed.
arrow_px_up.gifTop of page
Sep 27, 2008 | Gateway 830GM PC Desktop
I have a advent t5250 laptop with a faulty screen if you connect it to a monitor all is ok and if you move the screen on the laptop with both hands in a twisting motion the screen comes to life untill you...
There is a video cord that runs from the motherboard to the screen it may be loose and needs to be re-seated back in place, or the problem is in the display itself which would be the worse scenario and would require a full screen replacement.
Feb 02, 2011 | Computers & Internet
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
Moved WNR2000 from 1 room into another and now router only connects with wireless units not the desktop it sits next to. Any suggestions?
Are you sure the cord is good from the router to the computer? It's either that or maybe a bad plug. Try another cord, and if that doesn't work, it's probably going to be something like a bad plug, or maybe a slightly loose modem board, since you moved the computer. All I can think of for the situation, hope this helps.
May 07, 2010 | NetGear WNR2000 Wireless Router
I was reading email and the computer screen went black. No lights on, nothing. No noise, nothing. Battery good. Power cord light is on. Is this a blown motherboard?
No first try 2 things
(1)Reattach the RAM memory.
(2)Reset bios settings to factory defaults.
For that you need to open back cover of laptop then reattach the ram memory also make sure your ram memory working fine.
then pull cmos cell from motherboard for 10 minutes then all settings defaults.
Then if same issue then you need repair your motherboard or lcd screen display.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 09, 2010 | Dell Vostro 1500 Notebook
Moved computer and now will not turn on
there is really no special part
here is one i found that will do you just fine
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3255390&Sku=ULT-LS350
only thing you need to watch for is if its a 20 or 24 pin connector that you need
the link i posted is for both
Apr 28, 2009 | Compaq Presario 5000 PC Desktop
A few of the keys on my hp pavilion dv6000 came off today- I reattached them and now my computer screen is blank when I turn it on. The power light is on and you can hear it running but nothing on...
try pressing the function or fn keydown and hold it down then press the the f key that turns off and on the display.Do the key that came off feel the same as the other keys when you push them.it could be that the keyboard is damaged and some keys may not be working as in the monitor key.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
Brother tripped over speaker cord
open up tthe speaker case and resoulder the leads/unless the wires pulled loose from the speaker face on the back of the speakers that should fix the problem,if the wires are pulled loose from the speaker face then reattach them with a drop of craze glue and a small drop of silicone sealer which should do the trick!
Jun 02, 2008 | Logitech Z-2300 2.1 Computer Speaker...
Computers & Internet Logo
95 people viewed this question
Alun Cox
