Question about Dell 5650 Computer Speakers
No sound from built in speakers the optiquest vs11443 monitor
    Problem Solver:
  • 15 Answers
Please change the integrated circuit.Or change the amplifier.
Posted on Jan 21, 2009
  • Sujith Andrews Jan 21, 2009
    please change the integrated circuit.Or change the amplifier
Please help me my optiquest q19wb model #vs11443 is shuting off aftre 1 second i opened it and no capacier were damadged what is wrong... the unit is not old 2 years i am not rich and want to save...
The usual problem with this symptom is an CCFL power supply failure. The inverter is the board that powers the backlights so you can see what is on the screen. If you look really close and with a flashlight, you may be able to see the dark shadow of the image on the screen. Without the backlight, the LCD is useless.
You can get parts from places like http://www.lcdalternatives.com/ or eBay. Search for the model number and "repair" (e.g. "Optiquest Q19wb repair") on eBay.
Apr 12, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Cannot turn on the microphone on my monitor model number vs11 443
Q19WB (vs11443) does not have built-in microphone, see user manual here: http://www.viewsonic.com/assets/034/8841.pdf
Are you using WEB CAM with micorphone built-in?
Please leave rating ifit helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Mar 03, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Modle VS11443 the monitor will only stay on for 30 seconds and then the screen goes off
Look for bad caps with domed tops as shown in my Optiquest Q19WB (VS11443) here: http://s807.photobucket.com/albums/yy352/budm/Optiquest%20Q19WB/
Please read my guide before DIY repair.
Jan 24, 2011 | ViewSonic OptiQuest Monitor
The built-in speakers no longer work. The icons register volume changes, but there is absolutely no sound at all.
You need to feed it with another sound source such as a MP3 player to see if it works, if it does, then you PC sound card/drivers/software/setup may be the problem. If it is the monitor, then it can be the power amplifier IC which is not worth repairing, you will be better off spending money on a good set of powered PC speakers instead that will give you much better sound than the monitor's speakers.
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 04, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
All of a sudden, no sound
First, we need to find out if the problem is in the monitor amplifier or in the PC sound card.
Try feeding the monitor with MP3 player first, if you do not get sound, then you need to open up the monitor and find out if the amplifier is getting the 12vdc feeding it. It will not be worth to have the monitor repaired by the shop because the amount of money for repair will be better off with new powered speakers system tahe will give so much better sound than the built-in speakers in your monitor.
http://www.badcaps.net
May 30, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
I recently bought a Windows 7 64 bit PC. I have Optiquest monitor with built-in speakers. The sound was working fine and then it stoppped. I tried stand-alone speakers, then anoither monitor with speakers-...
Go into control panel / sounds / sounds and audio / select audio blind / should see a driver listed in each device. Back to sounds blind /test sound, if you can see the black arrow but its greyed out then driver is faulty. If you can click on it and it changes baxk to th esquare all is OK, ensure the sound jack is plugged into the GREEN ones at rear PC. Also check in volume blind that speakers are selected.
Feb 24, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Cannot raise the volume
Speakers built in to monitors are notorious for being quiet. But, check the sound in control panel and see if it knows you r useing that type of speakers. And of course check monitor itself for a manual volume control.
Jun 24, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
My Princeton VL1919 has built in speakers, no sound
Are you plugged into the right Line Out port on the computer? Is the volume icon muted?
Feb 06, 2018 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Sound
please change the cable connecting cable of speakers.
Jan 21, 2009 | Audio Players & Recorders
Speakers
you need to ensure that the speaker lne cable is connected, this should be a double ended 3.5 jack plug cable, one end plugs into the back of the monitor, the other goes into your speaker port on the motherboard of your computer, sometimes there is a power cable required too
Oct 08, 2007 | ViewSonic OptiQuest Monitor
Dell 5650 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
