Question about RCA 27F534T TV
RCA 27F524T Power comes on But no Picture
When you turn on the TV it sounds like it it going on.. Power up sound like in the picture tube, but then no picture.. Can't turn it off from remote or pressing power button. I have to unplug from Serge protector after turning the protector off
  • NeilKent Apr 13, 2009
    Same problem. Push the power button and it turns blue, but no picture from any source (including just trying to get the menu up) and then won't turn off again unless I unplug it. Unit is two years old!
    Any suggestions??
I want to know who wants to sell me their rca t.v?
Posted on Jan 24, 2009
My Tv has sound but no picture. It is 12 years
may your picture tube in bad condition or no filament voltage
Feb 25, 2010 | RCA F36674ET 36" TV
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
No picture, sound ok
Rca has been known to have bad solder joints in the deflection circuits. Usually around the flyback and transformers.. check it over real good. Just be careful as you can still get shocked after the powers removed the capacitors and picture tube will hold a charge in them.
Jan 21, 2008 | RCA F36649 36" TV
No picture has sound, then picture comes on after a while
check for a problem with the horiz.output circuit. maybe bad solder connections or the horiz.osc.
Sep 15, 2007 | RCA F27442 27" TV
No picture or sound
The most common cause for a bowed picture is the convergence power supply module. The module will fail and sometimes blow the fuse. Average cost of repair would be around $100, if you brought it to a tv shop, more for in home service.
Sep 08, 2007 | RCA P46920BL 46" Rear Projection...
RCA 27F534T TV Logo
260 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
