Question about Intel 1.6GHz Celeron Dual-Core E1200 800MHz 512K LGA775 HH80557PG025D
I have a lg computer (core 2duo,512ram,160gbhard disk) it dosent runs the writex cd also it shows CRC failed error.
    Scholar:
  • 55 Answers
That means that whatever information there is on the writex CD may be corrupted.
Posted on Jan 27, 2009
I HAVE NO NEW XP WINDOWS RECOVERY CD FOR MY MEDION MIM2220 SO I CANT START WINDOWS , WHEN I TRY TO INSTALL FROM RESTART IT COME WITH THIS MESSAGE WHILE TRYING TO BOOT ( AN ERROR HAS BEEN ENCOUNTED THAT...
Do you have the original installation disk that came with the computer? You can try to boot from that CD and do a repair installation. The Cyclic Redundance Check (CRC) error refers to the media the computer is trying to access (either the CD or the hard drive). Try booting into Safe Mode (reboot and press F8 repeatedly until you get a boot menu). From Safe Mode run a checkdisk (chkdsk from command line) on the hard drive to find and repair any found disk issues.
May 25, 2011 | Medion (40010998)
Crc error whill staddpro software install.
The CRC error is a data error on your software installation disk.
If the software is on a CD check the CD for dirty marks and scratches, if necessary get a replacement CD.
If it was downloaded from the Internet then download it again.
Feb 09, 2011 | Compaq Presario R3000 Notebook
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
When i try to install the sims 3 File: E:/Chaches/Sunset Valley.objectChache Error: Data error (cyclic redundancy check). pops up i cleaned the disc but it didnt help
If 'E:' is your CD/DVD drive, then some of the data could not be _correctly_ read from the disk.
When the data was written, a CRC value was calculated for the data, and that CRC-value was written onto the disk immediately after the data. When the data is read from the disk, the CRC-value also is read from the disk. A "new" CRC-value is calculated from the data that was read, and the "new" CRC-value is checked against the "old" CRC-value. If the two values do not match, then the data retrieved does *NOT* match the data that was written, i.e., you have an "I/O error".
Take the defective CD-ROM back to the retailer, and get it replaced, under warranty.
Nov 21, 2010 | Computers & Internet
Will not recognize cd when inserted
Try This:
1.click on start->all programs->run and type in run box devmgmt.msc
You wil find a device manager box now you need to click on the symbol called "scan for hardware changes". Now once the changes is complated then restart the computer and see if you can view the cd's. But before doing so check that whether the cd drive icon is showing in the My Computer or not.
2.If the above solution dosent work out than try cleaning the lens from the lens cleaner disc. You can purchase it from any local computer shop.
3.If the above two dosent work out then probably its a chance that you need to change the cd player.
Sep 25, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Crc failed
> my disk is new .. provider says that there is a problem in my PC ...
Without running any disk-diagnostics, how could he be correct??????
> CRC failed
CRC === Cyclic Redundancy Check
When a block of data is written to the disk-drive, a CRC-value is calculated, and also is written to the disk-drive.
When a block of data is read from the disk-drive, the CRC-value is recalculated, and is compared with the CRC-value that was written.
Any difference between the "old" and the "new" CRC is an indication:
* the disk-drive is faulty
* the RAM in your computer is faulty -- like trying to write with a pen onto paper covered with butter, any values written into the RAM cannot be _exactly_ read back from RAM. So, the calculation of the "new" CRC has produced an incorrect value.
On another computer, search for 'MEMTEST86+' -- download this free software, and write it to a 3.5" diskette or to a CD-R. Then, boot your computer from the diskette or the CD-R, and let 'MEM(ory) TEST' run for a few hours, in order to perform extensive testing of the RAM in your computer.
Dec 02, 2009 | Microsoft Windows XP Professional With...
CRC Failed
Two issues will cause this kind of error. #1, bad optical drive(bad cd drive) #2 Bad memory. You can replace either one by yourself. To have it properly diagnosed on which one of these it may be, take it to your computer shop or replace both items yourself depending on your budget.
Jan 16, 2009 | Computers & Internet
Re-installing xp
A cyclic redundancy check (CRC error) is an error checking program that is used to verify data and can be caused by hardware or software. The most common causes are bad CD disk, hard drive or memory. To run diagnostics press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Examine the Windows CD and see if there are any scratches or smudges on the media, try another CD disk if you have one.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Latitude D600 Notebook
Motherboard driver
i lose my Merury Mainboard Cd i nead the Drivers for PI945GCM Can any one help
Oct 21, 2008 | Intel Motherboard
Intel 1.6GHz Celeron Dual-Core E1200 800MHz 512K LGA775 HH80557PG025D Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
