Question about Cambridge Soundworks P500 Speaker
Cambridge SoundWorks P500 Subwoofer Control Module
Doesn't work
5 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Posted on Nov 26, 2007
freetek
  • 5568 Answers
SOURCE: My Cambridge SoundWorks 88CD is
A couple of possibilities- If there is no fuse holder on the rear of the box, it may not be user-replaceable but soldered onto an internal board. If it has blown, either there has been a component failure in the power supply that caused the fuse to fail or the supply is not starting up as it should, a problem caused by cheap capacitors in certain areas of the supply. Unless you have at least a multimeter, this is not a good choice as a DIY repair.
Posted on Jun 17, 2011
mc1bean
  • 3053 Answers
SOURCE: How can I replace a
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Posted on Jul 07, 2011
arniequan
SOURCE: cambridge soundworks 740 display too dim
Mine is dim also. Apparently sending it in for repair is not an option.
Unfortunately, the CD740 radio has reached end of service life. Parts are no longer available & we cannot repair them. We apologize for any inconvenience. If you need further assistance, please call us at -800-367-4434, Monday - Friday 9AM to 6PM central time.
Best Regards,
Sales and Support
Posted on Sep 24, 2012
Control module
The connections on the control module all depends on what outputs are available on the receiver or whatever audio component you have.
Probably the most straight forward hook up is to connect the receiver's speaker (R &L) outputs to the speaker Inputs of the module, however you may have potential outputs on your receiver that could used. What I suggest is for you to provide the information on the receiver with make and exact model number so the receiver outputs can be matched to the model. http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000030686.pdf
The link is for a system module manual, and it describes all the possible hook ups based on the outputs of the receiver. If you can provide the additional information on the receiver, I will try to asssit you further.
Jun 02, 2014 | Cambridge Soundworks ton Theater MC300...
Woofer has popping noise
I have the same problem with my Cambridge Soundworks CSW250. Also one of the speakers doesn't work all the time. I'm sure it's a loose connection on the circuit board. When I tap the subwoofer near the connections, the popping noise changes (gets worse, better, other speaker works,etc.).I tried taking the subwoofer apart, but the area near the connections is sealed with glue, so I cannot access it. I hate it because when it works,it sounds so good. Anyone know how to get just the circuit board and back panel?
Aug 09, 2012 | Cambridge Soundworks Audio Players &...
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
My Cambridge SoundWorks 88CD is not working...no display, no sound, the CD doesn't spin. Any hints? Thank you.
Jun 17, 2011 | Cambridge Soundworks 88CD Clock Radio
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
My Cambridge Soundworks PSW 12"
Take it out and look at it if you're going to replace it anyway.
or
Get a whole new speaker for cheap...
http://twintiers.craigslist.org/ele/2281123193.html
or
Call 800 376-4434 USA or 800 525-4434 Canada for factory assistance. (It's printed right on the back.)
Apr 20, 2011 | Audio Players & Recorders
Lost Speaker Sound
It does sound like a connector issue, don't you think?
What happens if you DON"T touch the connector but move the volume control on the controller?
Have you tried looking outward toward the source?
Mar 30, 2010 | Cambridge Soundworks P200 Subwoofer
Sony V555ES Amp:
Try setting your amp to "auto format decode".
It should easily be heard in this mode.
The sub will not show up on the display when in 5.1 mode. (Blue light on)
Use this with music, and use the 5.1 with movies to get a better experience from your amp.
The sub will work in 5.1 but doesn't show up in the display. Try movies with loud sounds.
Most of the pre-set sound fields are of no use to me. I only use normal surround, and AFD and love it. I hope this works for you!
Terry
Jul 03, 2007 | Sony STR-V555ES Receiver
150 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
