How to change brushes on beko washing machine
Can you help me chnge the brushes on my beko washing machine????
  • 4 more comments
  • Anonymous Mar 12, 2014
    I need to change the motor brushes on a beko wmi71641
  • Anonymous Mar 18, 2014
    I NEED TO CHANGE THE BRUSHES ON MY BEKO WASHING MACHINE MOTOR
  • Anonymous Mar 23, 2014
    drum seems to have dropped
  • Anonymous Mar 24, 2014
    water in filter compartment every wash
  • Anonymous Mar 28, 2014
    How do i set the time of day on the BEKO WMB 61631 W washing machine if it can be done?
  • Washing Mach... Master
  • 3,463 Answers
Remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 11, 2014 | Beko WM5140W
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 08, 2013 | Beko Washing Machines
Beko wma 10w wont spin how do i change the brushes
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. these videos should solve all your problems
Jan 21, 2013 | Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
May 17, 2012 | Beko Washing Machines
Beko washing machine wont go into full spin
Carbon brushes on motor need renewing. Not terribly difficult job. Be sure to disconnect from power before attempting.
Feb 28, 2010 | Washing Machines
Changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
May 07, 2009 | Washing Machines
Washing Machines Logo
2,246 people viewed this question
Top Washing Machines Experts
