Question about LG Art Cool LA181CNW Split System Air Conditioner
How to replace remote receive sensor - LG Art Cool LA181CNW Split System Air Conditioner
I need to replace the infrared sensor unit for Vizio L37 HDTV.
Good day!!!
Before I answer your question let me clarify something..
  1. What sensor you need to replace is it on the remote IR (infrared) or the receiver on your TV?
  2. Did you try other remote control?
  3. How did you say that you need to replace the IR sensor or receiver on your TV?
To test the remote please use a digital camera..How? place the shot to infrared of your remote then look at the screen of your camera after that press any button on your remote and look if the IR sensor lights up..
Please answer all my clarifications for me to diagnose the exact problem..Because replacing of IR sensor on TV is difficult..
Thank you for using fixya and choosing my service..
Dec 11, 2011 | Televison & Video
My remote has stopped working. We have replaced the batteries with no luck because of this we cannot switch between sources My TV is a Philips 42" Model # 42PFL3603D/F7 Serial # VA180905005250
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
Mar 10, 2011 | Philips Televison & Video
Remote control No work
Try another remote control, if it is also not working that means remote sensor in tv got bad and become unable to receive remote signals, replace remote sensor in tv.
If other remote works then replace batteries in bad/ suspected remote and check.
Let me know model and brand of your tv if you have additional question.
Thanks.
Dec 26, 2010 | Samsung Televison & Video
Remotes does not function at all. Tried two different remotes, only manual switches work.
Remote sensor/ receiver mounted at tv front sounds defective and unable to sense/ receive remote signals.
Replace infrared remote sensor in tv to fix the issue.
Jul 18, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony Bravia KDL-40D3000 no longer responds to the IR remote. I also have a 46 inch Bravia, and the remote does work with it. The front panel controls work okay. The remote worked for about 2 years, then...
Had the same problem. The infrared receiver quit working. Could not use the factory remote or the cable remote. Simple fix- I just cleaned the infrared receiver. Both remotes now working.
Mar 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Remote sensor is not working I assume, i have been unable to get any universal remote to work so I am thinking it is the actural sensor in the reciever. My receiver is not on the list. I inherited an...
I doubt that its the sensor. you can check at radio shack for a replacement remote. I have yet to see a universal remote that controls receivers. they would have to order it if available. use the catalog # on the back of the receiver (31-XXXX) or let me know the # and I can check into it for you. is it an stav3560 or 3250?
Nov 07, 2009 | Optimus STAV-3560
Remote not working receiver on Pioneer vsx1016txv-k
Request a service manual directly from Pioneer.
May 09, 2017 | Audio Players & Recorders
Remote
The remote sensor assembly on the front panel of the amp will need to be replaced. It is the small tin shielded box with 3 wires connecting to it(behind the remote sensor window). Check that the sensor has still has 5 volts to it before removing. Some models have a 5 v reg IC on the front panel to run the sensor
Jan 12, 2008 | Pioneer VSX-D457 Receiver
Remote control not working...
I'm not sure of the exact fix, but when these components were assembled a few of the connections involving the remote sensor were not saudered. An easy fix if you know where to look.
Apr 15, 2007 | Kenwood VR-405 Receiver
LG Art Cool LA181CNW Split System Air Conditioner Logo
32 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
