Question about Ovens
Inner glass door shattered on matsui msf60ss - Ovens
Krazytech
  • 725 Answers
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
  • 4 Answers
SOURCE: kitchen aid oven door glass shattered
gget a new door
Posted on Jun 21, 2009
SOURCE: inner glass on bosch HBC84k550b microwave
Strangely enough I had exactly the same problem but today managed to fit the new inner glass and door panels without any problems, here is how.
YOU NEED 2 PEOPLE FOR THIS STEP. Open the door, at the top are 2 large plastics flat head screws, undo these making sure your helper is holding the door securely or itll fall on the floor, te door will unhook once the screws are fully undone
Once off you can close the microwave back up.
Now there are two screws, one in each top corner holding a funny looking plastic wing shape that slides into the inner door. They have a star screw head. Undo both of these and remove the plastic wings. When you remove these the panel underneath will try to fall off so be prepared to catch it, along with the plastic screws undone in step 1. This now unhooks like the main door did.
From here you'll be able to see the back of the inner glass. This is held in by a mesh at the back and about 15 screws, star headed again. you can simply remove all of these, that will release the front panel over the inner glass, again, you might want someone to hold the door open so the panel does not drop when you remove the last screws.
Thats it as far as taking the microwave apart. put your new glass in, remembering to make sure the rubber seal is put back between the glass and inner door.
Simply reverse the process.
It took me approximately 1 hour and I am by no means a DIY person.
Good Luck
Mike
Posted on Feb 11, 2010
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Korting oven
contact the dealer/ distributor in your area or contact the maker direct. You may be up for a new door as sometimes the glass is glued into the door for sealing purposes.
May 18, 2013 | Ovens
My inner door on my new world cooker exploded could it be i put it the wrong way round
Hi, it sounds like you put the door on yourself? The inner glass of my oven door (less than 1 year old) shattered when I put it in cleaning mode. We had to call a serviceman which fortunately was a part of the warranty we purchased and he said it could have been a microscopic fault in the glass, but he replaced it and it's been good to go. I've never heard of installing the door yourself for an oven, but even so, I just thought I would share our experience. It's a dangerous situation since it could shatter outwardly and hurt you or someone else so you might want to ask for a service person to come and look at it. Hope this helps!
Mar 13, 2012 | Ovens
Kuppersbusch microwave door glass replacement
Did you resolve your problem as my inner door just shattered and will need replacing? Do you know why yours broke?
Jan 09, 2012 | Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
