Question about Exercise & Fitness
I have a reebok edge 2.2 treadmill whilst using it the belt stopped but the display was still working.checked the glass internal fuse and this was fine would it be the motor?and how could i check to see if it is working
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
SOURCE: We purchased a reebok edge
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Posted on Mar 03, 2011
ercupa190
  • 12223 Answers
SOURCE: reebok edge 2.2 treadmill stopped suddenly then
1) Inspection if the fuse is the correct Amper and Voltage: example: you can not connect any FUSE less if they use 10Amp, not use 5 amp, or 15amp. That situation is delicated.
2) clean contact fuse, and retight the clips of the fuse, and tight the wire to the clip of the fuses.
3) The motor is Short or ground: Test with Some DVOM, maybe the winding is short,and need maintenance: brushes, grease, and clean, bearing. or the winding is faulty.You can go to some Shop for repair electrical motor.
sincerely.
E.CUADRA
Posted on Nov 04, 2011
ercupa190
  • 12223 Answers
SOURCE: The running belt has come off my reebok I-run
1) Lube the deck belt inmediately, this happen because the electronic system protect itself, shut down.
2) Lube the rollers bearing very well
3) MEAsure the voltage input motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are not THe board is faulty.
see the block diagram
God bless you.
Posted on Jun 19, 2012
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
There is what seems to be a light oily substance on the edges of the tread. Any ideas what this might be?
HI,
It would be the lubricant that used for the treadmill belt. you have to lubricate the treadmill belt at least twice in an year.
Check the video
Treadmill walking belt lubrication
www.electro-medical.blogspot.com
Sep 17, 2015 | Reebok V 680 Treadmill
My reebok edge stopped working and tripped my red on mains, belt won't drive although it goes up and down, found fuse on board inside which is glass and was very black, broke getting out can i get...
I would say the blown fuse was definitely "a" problem but not necessarily THE problem. Something caused the fuse to blow and it is likely with the belt drive system as the lift was still working. Look for burned or shorted places on the PCB and check the motor. You will definitely need another fuse - get 3 or 4!
There are several motor troubleshooting vids on utube. If this one isn't helpful, try some others.
Jan 11, 2015 | Reebok Exercise & Fitness
God bless you.
Jun 18, 2012 | Reebok treadmill i-run s
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
managua, nicaragua. c.a
Feb 17, 2012 | Reebok Exercise & Fitness
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
Feb 11, 2011 | Reebok 8000 ES Treadmill
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Nov 25, 2009 | Reebok Vista Treadmill - RBTL13305
Exercise & Fitness Logo
144 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
