Question about Imperial C2036PS1-TW Kitchen Hood
Cannot disconnect phone line when fax is sending
When a fax is scanned we cannot disconnect the phone line if we decide that the fax does not need to be sent.
  • 26 Answers
PRESS CANCEL ON THE FAX THAT SHOULD END THE TRANSMISSION
Posted on Jan 23, 2009
I have a Brothers Laser Fax Super G3 and I need someone to come and hook it up for me. Whenever the phone rings, the fax goes off and I have it indicated for phone/fax mode. Can you send a service p
Hello
Make sure your fax line just connect to one device (just fax device)
sometimes other device cause this problem.(and you must know most (old ) telephone lines can handle up to 3 devices (if you connect more than 3 devices, you may have some noise on the line or disconnected other devices issue or even your line fuse may damaged due to low amperage.
what you can do?:
1- disconnect another device and check
2-use another line
3-use ADSL Splitter to decrease your noise on the line
4-check your telephone cable for probably damaged
5-go to certified repair center for checking
regards
Ali Karbasian
Dec 08, 2014 | Brother Office Equipment & Supplies
Can you send a fax using an hp deskjet f2430 printer, scan, copier?
Yes you can, but not without the aid of your computer. You will need a dial-up modem installed with a phone line connected, and some fax software. Then the actual fax sending and receiving is done by the computer, while the all-in-one just serves to scan material for sending and as a printer for receiving. But the printer can't be used as a fax machine all by itself.
Mar 04, 2011 | HP LaserJet 2430 Printer
Image on fax send report is set to off how do i change it to on so that i can fax out
The Fax report only tells you if the fax went through or not. The image on a fax report lets you quickly check the first page of the documents that were faxed (or supposed to be faxed). To get the image on the fax report, press Setup > Fax Confirmation > On Fax Send. Then select On for Image on Fax Send Report.
What you need is to test that your machine can send a fax. Make sure that the unit is installed correctly. Use the phone cord or adapter that came with the unit between the appropriate wall jack (on PBX systems for example) and the 1-Line jack. See the User's Guide if the phone is shared (voicemail, computer modem, answering machine). To test the unit, press Setup button on the Control Panel (the icon looks like an open end wrench). Choose Tools and Run Fax Test. This will check if the machine has a dial tone and can send information on the phone line. Use that information to troubleshoot the issue. For a hardware failure, cycle the power (turn off and unplug the unit) and check if there is a dial tone (I like an old corded phone for this test). If at all possible, if the test fax is unsuccessful due to a dial tone problem, disconnect all other devices on the phone line and retest. Then reconnect them one at a time to see which may be involved in the failure. Check that you are on an analog phone line.
Once you get a successful test fax, load your original (face down on the scanner glass or face up in an ADF). To fax from the all-in-one, enter the recipient's fax number with the keypad then press Start Fax black (or color as needed). (If the recipient gets poor print quality, adjust the scan resolution. This is under Options after you press Fax and then enter the destination number. This method also lets you chose when to send a fax.)
After you get the fax to work directly from the all-in-one, then you can set up the HP Solutions to fax from the computer.
I hope this helps.
Aug 09, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Is there a fax number for people to fax you?
Yes,
It is the phone number assigned to the phone line you plugged into the fax machine. You Fax machine is basically a Modem listening to the phone line. Someone dials and if they are sending a fax, the two machine's make squealing noises called a "handsake" then connect sends data.
It is then stored or printed or both.
If you pick up the phone while the two fax machines are connecting.
You will most likely disconnect the data transfer and get an ear full.
Hope this helps!
Nov 17, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have Linksys modem no AM300.I try and send a fax and it will not go through Error report "NO Answer" BUT I know fax machine on other end is ok.Internet is ok.Can you help John
Even though you have internet, have you connected a phone line? Most fax machines/software rely on the phone line. I don't know how you are sending a fax. If you are sending a fax directly from an all-in-one, you'll need to connect the phone line to the back of that device. If you're sending a fax using a program on the computer, you'll need to connect the phone to the back of the computer.
You can temporarily disconnect your land-line phone and connect it to the all-in-one or computer. Just remember to reconnect it when you are done so you can receive phone calls.
I hope this helps!
Sep 07, 2009 | Linksys Computers & Internet
How do i send a fax with my cannon MX310 what are the steps?
Plug a phone line into the LINE port place original face up on the feeder dial the fax number press START (fax)
Jun 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
I got my all in one printer last Spring. I was told I could use it in place of a fax machine,no land phone. I have never been able to figure out how to scan and send to someone. Now I need to scan and...
1. In order to use it, or any other fax machine, you need to have a land line phone.
2. Some printers don't have a built in fax, but rely on the computers internal fax modem and software on the computer to send a fax. But then your computer will still need to be attached to a landline phone.
Jul 04, 2008 | Office Equipment & Supplies
Fax machine will send faxes but will not receive any
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Apr 11, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Won't receive fax calls canon pixma mp830
Apr 03, 2008 | Office Equipment & Supplies
Imperial C2036PS1-TW Kitchen Hood Logo
233 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
