Question about HP Office Equipment & Supplies
Hp officejet J4660 does not print
The paper feeds into the the printer and stops half way out with nothing printed on it, while saying printing, then stops responding
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
sfda410
  • 20 Answers
SOURCE: My HP Officejet 5610 All-in-One won't copy or scan any document
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a7
Posted on May 27, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Says it is printing but the paper won't feed through to print and I can hear the rollers but nothing happens
If you can see head printing
Probable: dirty rollers (clean with soap or ether)
Possible: paper too light
Feb 06, 2010 | HP Officejet 4315 All-in-One Printer
"out of paper"
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 05, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP C4100 Series Printer - Paper Feed & Print
The feed rollers might have to be cleaned or it could be a logic problem (main board) issue.
Jul 31, 2009 | HP Office Equipment & Supplies
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Officejet 4215 not printing
It could be an empty/dried up cartridge depending on how old it is. If the printer just feed the paper straight through without trying to print(i.e. the printing head is not moving), then it is most likely a configuration problem.
Sep 10, 2008 | HP OfficeJet 4215 All-In-One InkJet...
78 people viewed this question
Seeker5211
Seeker5211
