Question about Compaq (152839001) (Refurbished) Tape Drive
Tape drive I need to know some main and basic problems with tape drives, which i can face in the future. I'm working in IT company, which is administrating servers with Compaq tape drives. Maybe you can provide me some information about trouble shoting and solving some basic problems. Please, send me an e-mail with some main tape drive problems and how i can solve them...(myrro.v@gmail.com) Thank you for help. Miro
  • 416 Answers
First of all Tape drives are hard to find as technology is fast moving. warranty will be a issue & you will have hard time finding tapes. also storing tapes is not going to be easy
Posted on Jan 21, 2009
What are the problems are facing by teenagers?
Study pressure, Constant need to look good, a Constant pressure to excel in all aspects of life, Addiction to the social network, Drinking and smoking are some of the few problems faced by teenagers today. https://www.inlifehealthcare.com/blog/teenage-problems
Jun 29, 2016 | The Health & Beauty
How do I put top and front back on unit?
1.) Possibly the small hairspring in the dust door is not set.
2.) the alignment between the front face plate and the carriage are not meeting up properly.
3.) there is also a pressure switch on either side of the carriage about 1/3rd. of the way in that senses the tape cartridge and triggers the tape loading mechanism. Check multi wire cable or ribbon control cable between front of unit and main circuit board for cracks tears or loose connection.
Without more information on the behavior of the problem I can not be more specific. Good luck with the basic troubleshooting list I have given you and get back with more info if these prove fruitless.
Apr 30, 2014 | Philips MWD2205 DVD Player/VCR
Cant acees files on maxtor basics
try to use it via usb to SATA converter then u will see if it really work or not , if not try to use the same usb to SATA converter on another computer if doesn't work then ur harddisk controller is broken and u need to give it to its company to recover ur data
Jun 06, 2009 | Maxtor Hard Drive
I have a problem with my harddrive
Your drive is basically dead. The clicking you hear is the actuator arm for the r/w heads resetting as it trys to read the drive. Can be caused by a worn main bearing. Usually caused either by age or the notebook being dropped. When off the hard drives can sustain a fairly good impact 3-4 ft and still likely survive, however when in operation they don't respond well @ all when dropped from even a small distance.....
Virtually no way to repair. If data was critical, there are companies that will open the drive and recover the drive contents, but it is a costly procedure!!!
You will likely need to replace the drive. I had a situation once where tapping the hard drive lightly near the drive motor has got a drive to spin up one last time, but, only seen it work once. Not a recommended procedure; but worth a try if you're desperate..... Did you backup your data? If not, maybe a practice to start in the future.
Jan 28, 2009 | Western Digital 250GB MyBook External USB...
I get an error code A4 and 8A on the value loader LTO library.
I opened the library, removed all slots and put them back in with proper alignment. It's working now..
Nov 13, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
ADIC Scalar 24 LTO2 Drive issue
We have the same problem with our ADIC Scalar 24. The only way we have been able to eject the tape is to cycle power on the tape library and after it has finished reading the tape barcodes, we can use the front panel command to unmount the tape that is in the drive. We haven't been able to find a solution to the problem and it happens at least once a week
Mar 29, 2008 | ADIC Scalar 24 (90079801) LTO 2 Tape Drive
Main drive belt
The belt is old and has stretched.
Jan 12, 2008 | Seagate STT320000A Travan Tape Drive
Can you fix it?
It sounds like your first drive is defiantly shot. The second one suggests the drive has failed as well. You should be able to eject the tape manually using a long piece of steel. Such as a paper clip.
Taken from the manual
If all the right side or left side lights flash on the front panel:
There is a fault with the drive.
1 Try turning the power switch on the drive off and then on again.
2 If the problem persists, call for service.
So your sorda up a creek. Can i suggest moving to HDD backup system? They are ultra cheap, reliable, and much faster than Tape backup systems.
Alternativly if you have data you need to recover, you can purchase new (used) drives off ebay for about $200
Sep 19, 2007 | HP C5726-69202 SureStore Tape Drive
Resetting company voicemail
First, there are two things you need to know. The DKT3010 phone will work on different Toshiba phone systems AND you can have different voice mail systems. The phone system and voice mail are separate to some extent. You need to know the model of the Toshiba main control unit and it would help to know for sure which voice mail system you have. You SHOULD have an administrator's guide for the system and voice mail or someone at the office in control of making simple changes to the system... however, depending on the company that originally installed the system you may have gotten nothing (hopefully they are still in business and you know who they are!!) Most of these systems can be programmed over the phone quickly by the company that originally installed it. There are probably passwords that you would need to know to change any programming features and if you don't know what they are you would be out of luck. Your best bet is to find the company that installed the system. There may even be a sticker on the main control unit with their contact info. Next I would try to find a local installation company that could help you get the changes made and set you up with a way to make future simple changes yourself. Get ALL the information needed to make any changes like passwords etc.. even if you do not want to do it yourself, you NEED to have this information in case the company goes out of business!
Aug 14, 2007 | Toshiba DKT 3010 Corded Phone
Computers & Internet Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
