Question about Maytag HAV2360A Top Load Washer
HAV2360AWW clothes are still dripping wet after the spin cycle
IFIXALL
  • 868 Answers
SOURCE: Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Posted on May 26, 2008
  • 36 Answers
SOURCE: clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Posted on Dec 17, 2008
SOURCE: Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Posted on Jan 22, 2009
Just_Bobz
  • 448 Answers
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Posted on Feb 21, 2009
  • 79 Answers
SOURCE: Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Posted on May 23, 2009
New washer- WTW5000DW0 / C43742143 clothes not spinning
are the clothes very very wet ? is the machine emptying properly? you could check that the pump isn't blocked or partially jambed I'd start at the pump first, barring that it could be the main program controler
Nov 30, 2014 | Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Maytag HAV2360A Top Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
