Question about 3M Littmann Select Stethoscope
Can't turn diaphragm to bell - seems stuck?
My littmann 3M classic II SE stethoscope for the past 6 yrs - has always been working well until a few mths ago (since I was in a job that doesn't require turning it to the bell much) it became stuck - how do I solve this problem?
  • 1 more comment
  • dddd Aug 14, 2013
    hello i had the same problem the solution remove the plastic Tunable Diaphragm and Rim and remove Diaphragm from the tube then pour some oil in the bell and let for some time and then try moving it it worked with me from the first try
  • dddd Aug 14, 2013
    yeah and the them clean the metals from any oil before putting everthing back
  • dddd Aug 14, 2013
    sorry then clean the metals from any oil before putting everything back
Hello i had the same problem the solution remove the plastic Tunable Diaphragm and Rim and remove Diaphragm from the tube then pour some oil in the bell and let for some time and then try moving it it worked with me from the first try then clean the metals from any oil before putting everything back
Posted on Aug 14, 2013
    Sergeant:
    Champion:
  • 373 Answers
Is there a rest button on it
just guessing
Posted on Jan 31, 2009
  • joyojy Aug 18, 2010
    atsherene, have u found the solution to ur problem above?
    cos my stet seems to hv stuck too!
Is a littmann classic ll S.E diaphragm rotate 360 degree
sorry , no it does not it should only rotate 180 degrees this allows you to change from the bell to the diaphragm. send it back to the factory, call them they may even send you a new one.
Mar 10, 2014 | Littmann Stethoscopes Littmann Classic II...
The diagram cover came off of my stethoscope. I can not get it to go back on and I need to use this stethoscope. I have only used a few times.
Normally, the retaining ring on the head of the stethoscope screws on and off, so the diaphragm can be cleaned or replaced, as necessary. Have you tried that?
Feb 18, 2011 | 3M Littmann Lightweight Ii Se Stethoscope
Help!!! my litmann 4000 wont turn on even with new batteries!!:(:( any ideas usually after fiddling with it then it work but not this time and i need it!
Hi,the problem is obviously from the internal battery contact of your device,or a the cord that delivers power to the unit is broken,you can take apart the stethoscope and fix it,but as a warning,the litmann 4000 is a very fragile and sensitive electronic stethoscope that requires high technique and expertise to fix,so i will suggest you contact a qualified stethoscope technician,so you don't end up ruining your stethoscope.
Thanks and take care
May 20, 2010 | Littmann Stethoscopes Littmann Lightweight...
There is no sound coming from the ear of my stethoscope. Do you have any suggestions?
First try new ear buds...they do get clogged just like ears! Next, replace tubing...it gets dry and will get fine cracks that are to even notice unless you are looking for them Littmann tubing does not contain latex...it does need to be conditioned with Armoral. I just found that out...after using mine for 7 years! OR>>>>buy a new one !!!!
May 13, 2010 | 3M Littmann Cardiology III Stethoscopes -...
Hello. Here is the manual http://www.wms.co.uk/Documents/product_pdfs/Littmann_Cardiology_III_Stethoscope_Instruction_Manual.pdf
You will see that the unit has a 5 year warranty and requires regular cleaning and maintenance in order to work properly. IF you can not tweek it so it will work by flipping the diaphragms then send it in for repair. the address in at the end of the manual. Joe
Mar 21, 2010 | 3M Littmann Cardiology III Stethoscopes -...
Where can i buy
you can buy it from the medical shop
Jan 31, 2010 | 3M Littmann Select Stethoscope
Have a ecg m1770a machine that is giving me a low battery error even when plugged in. What should I do?
Most ekgs need a strong battery even when operating on AC power. Replace the battery and that should fix the problem.
Jun 15, 2009 | 3M Littmann Master Cardiology Stethoscope...
3M Littmann Select Stethoscope Logo
1,372 people viewed this question
Top 3M Health & Beauty Experts
ray gallant
Tom Chichester
Are you a 3M Health and Beauty Expert? Answer questions, earn points and help others
