Question about Sony RMyD024 Remote Control
Rm-yd024 volume button not working
Volume buttons not working
4 Suggested Answers
digritz
  • 530 Answers
SOURCE: My Sony remote is RM-YD024 - I am trying to find
Here are all the codes for your Denon DVD player.
30490, 30634, 31634
Just in case you don't have the manual I also included the steps to input the codes.
Hope this helps
Follow these steps to program the remote control.
NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any type of equipment that is compatible with this remote control. For example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the INPUT button.
  3. While holding INPUT button, press the FUNCTION button for the desired component.
  4. Release both buttons.
  5. NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  8. Press the ENT button.
  9. NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
  10. Point the remote control at the component.
  11. Press the component POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, use the remote control that was provided with the equipment or purchase a universal remote control that has a learning function.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
Posted on Nov 04, 2009
joeguest2
  • 2080 Answers
SOURCE: All the buttons on my
Your remote control's internal button contacts on the circuit board may just need cleaning. If there is some residue, or debris, or oxidation inside on the surface of the circuit board it may be interfering with the correct operation of only a few buttons in particular.
It does not sound like a battery connection issue or a bad transmitter since most of the other buttons work fine.
You can try unscrewing, and disassembling the remote control in order to access the contact pads on the circuit board.
First check if there are any screws holding the remote control halves together. Be sure to open up and look inside the battery compartment as well. Once all the holding screws are removed, then gently pry the two halves of the remote control apart.
Use a cloth or a paper towel and some Isopropyl alcohol to clean off the surface of the circuit board and the underside of the button pads. Now check the circuit board for any signs of excessive wear, cracks, or oxidation on the copper contacts. You can use a pencil eraser to gently polish the copper contact pads on the circuit board if necessary. Once the unit is cleaned, just reassemble it and replace the screws and then try it out.
If you did see any significant damage inside or cracks in the circuit board, then you are probably going to have to eventually replace the remote. A wide variety of universal remotes to suit your needs and budget are available at any decent electronics store.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Posted on Apr 04, 2011
gopakumarg43
  • 75581 Answers
SOURCE: sony remote rm-yd024 okay button
There must be and 'Enter" button, if OK button is absent. Use this Enter button as OK button.
Posted on Jun 05, 2012
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
Chunghop universal remote RM-306E code for lg tv
if you are using CHUNGHOP RM-306E this would be applicable for all brands of TV..
1) Turn on the TV
2) Press S button (top left corner) until red light on
3) Press Green button (power button top - right corner)
4) press volume + button (blue at the middle on the left) until the volume signal display on the TV
5) press S button again
Now you are set..
Test the remote function it should be working now.. if not repeat the steps above until you got it working..
Good luck..
May 07, 2014 | Televison & Video
Rm-yd024 trying to find program code for comcast cable box
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 15, 2013 | Sony RM-YD024 Remote Control
Infrared on all the time sony remote
Hi Robert,
Most of these remotes are carbon pattern type closed switches. If you cleaned the PCB with other than a real pure solution like rubbing alcohol the pad may still be shorted continuously. The real problem is that if the button were sticking that usually mean there was a contaminant inside the remote which could be a drink or other spill. All that needs to be cleaned out. I use denatured alcohol but I do not scrub the carbon traces as they can be removed if not careful. A light cleaning with Windex might help as drinks are water based not alcohol based. I could take a look at the remote if you want. I repaired a number of them when I was Sony authorized and working at other places as a Chief Engineer. People seem to bring me things to repair- it is still going on but most cassette decks and Open Reel decks now.
E mail me at skywavebe@sbcglobal.net if you need help.
Aug 09, 2012 | Sony RM-YD024 REMOTE CONTROL PART...
Sony remote rm-yd024 okay button
Jun 05, 2012 | Sony Bravia KDL-46XBR6 46 in. LCD HDTV
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Can't surf chanels with the channel switch (+,-)
If this remote is brand new, I would say it is defective. I would return it to the store where you bought it. If it's past the 30 days mark. I would contact Sony they have a 1 year warranty.
1-800-222-7669 (SONY) International (Calling from outside the US or Canada): 1-239-768-7669
Jan 22, 2009 | Sony RM-V310 Remote Control
TRYING TO PROGRAM MY NEW SONY RM-YD024 REMOTE
Try these
For Direct TV:
00099, 00247, 00392, 00566, 00639, 00749, 00819, 01076, 01108, 01109, 01142, 01377, 01392, 01414, 01442, 01443, 01444, 01609, 01639, 01640, 01749, 01856, 20739
For Panasonic Satellite receiver:
00247, 00701
You can also look here:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMYD024
Nov 30, 2008 | Televison & Video
Volume buttons of Sony Remote control is not working for Akai TV.
Volume buttons on Sony remote will work on Sony TV only.
Aug 04, 2008 | Sony RM-V310 Remote Control
Sony RMyD024 Remote Control Logo
384 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
