Question about HP Compaq nx6310 Notebook
New ram installed, but computer screen doesnt work
Hi all, i have been working on installing the 2nd lot of ram into the 2nd slot on my laptop, (under the keyboard). No trouble inserting it, but when i put everythign together and turned comp on. nothign would display on the screen. I switched ram,, and still the same. So it's not the ram, it's just appears to be the ram in that slot.. I have the original ram in there atm (516mb, or something).. Anyone help me out?
cheers
  • 2 more comments
  • bill_peterso Jan 21, 2009
    Hi, i have switched the ram around, and each ram works in one slot, while the other one (original one) is in. But when its out, i can rotate the ram, around, (new ones), and nothing displays on screen, but computer turns on. What am i doing insactly, sorry. and thankyou for ur help.
    but the both rams work fine (one at a time) when they are in the eaasy access slot while the original ram is in. but as soon as the original one is out, and both new ones are in at same time. nothing appears on screan. like it is off..
    There are no other slots. thanks
    Lol sorry and thankyou for being patient, just looked up what fsb was. How do i check this ? sorry. and thankyou one again.
    ok goign to open it back up now. and not exactly sure where im looking, im guessin im looking near the slot for it. 512mb is the original one. my comp says it is compatible to run 4gb, will check somewhere now. sticker under the ram slot. :S..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
If your laptop working fine before install ram so that there should be problem with your ram only
check both rams are in same fsb there is no mater of capacity of ram (ie:512mb or 1gb)
like pc-2100
pc2200
or 667
both rams are intall in same fsb on both slots.
Posted on Jan 21, 2009
  • 2 more comments
  • yashan.co.in Jan 21, 2009
    check onother slot for desolding
    clean tips of ram slots with iso propile for rusting.
    my bro it is the problem of fsb i mantion before check that again.
    it is written on your ram sticker dude where the capacity (ie:512mb) is written on your ram.
My 2nd memory slot for ram is not working can this be repaired?
Beforeyouassume the 2nd RAM slot is faulty check the following.
When instaling RAM in the 2nd memory slot this RAM may not be compatible with the RAM in the 1st memory slot or the RAM may be faulty.
Try and use the same make, speed and size RAM modules.
If the RAM slot is faulty, chances are it cannot be repaired.
Aug 27, 2011 | Computers & Internet
I installed a new 1gb ram into the 2nd slot but when i turned the laptop on i get a black screen
Its probably that the new ram you added is not compatible with the one you already have. Check to see if both brands are the same. Also check if the ram works fine after you remove the older one and vice versa. If both of the RAMS work fine when installed individually, then they both are not compatible with each other.
Aug 26, 2011 | HP Computers & Internet
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
http://www.batterycentury.com/toshiba-tecra-m2v-s330-keyboard-p-79168.html
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
Trying to upgrade RAM on GA-945gzm-s2 mobo. Already have 1gb 5300 ddr2 stick of RAM. Works fine until I place the 2nd stick of RAM in. I turn it on and get no post beeps, no video, but everything is...
The new RAM module could be faulty or the second memory slot is faulty.
Try removing the original 1Gb memory module and inserting the new memory module in its place to see if the computer boots up normally. If it doesn't then then new memory module is faulty.
Oct 24, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
I have 2 x 2gb ram, and can't find 2nd slot for one of them
if you only have 1 slot, on the underside of the laptop.
it,s most likely, if there are any more slots, they,ll be under the Keyboard.
This will possibly be, where the 512 mb is now, although some laptops do have on-board memory chips from 256-512mb. ( try under the Keyboard )
Mike @ compurepair.
Jan 21, 2009 | HP Compaq nx6310 Notebook
Model #3522GZ gateway lap top
try right clicking c:\ tools scandisk fix problems reboot see what happens tried this on a lot of computers solved alot to
Jul 09, 2008 | Computers & Internet
Installing ram
It will support up to 4 gbs of ram but they both have to be low density, the unit can not go more then 2gb with high density ram.
Feb 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP Compaq nx6310 Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
