I have a problem with Sony DSR 2000 AP error code 09-020
Error code 09-020
  • 221 Answers
SOURCE: Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Posted on Dec 14, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Posted on Oct 28, 2008
  • 10 Answers
SOURCE: error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
Posted on Mar 22, 2010
SOURCE: Sony DSR 25, error code C3140. Any advise
My Sony model DSR-25 Videocassette Recorder will not play any tapes right now, due to a C3140 error. It occurred the other day when a tape I inserted was sticking. Does someone actually know what this error really means ?
Posted on Aug 11, 2011
SOURCE: 91-215 error code
how to solve the problem 91-215
Posted on Nov 11, 2011
C3210 error shows in sony dsr45 ap dvcam
C 3210 is means : LOAD direction loading motor timeout,
Main region how it happen are,
1.if there is moisture in ur TAPE or if ur tape had an slack tape during search And Video head is dirty.
Best is to clean head drum or disconnect the AC power cord.
After reconnecting it,
May 31, 2014 | Sony DSR-45 Mini DV VCR
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Jun 27, 2013 | Sony DSR-45 Mini DV VCR
Error code 09-028
not necessary.
Mar 22, 2010 | Sony DSR-1500 Mini DV VCR
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
Error 95-744 on DSR1500 AP sony
Main code 95 : Digital signal process system error and communication error with ICs
7 : STANDBY-OFF mode
4 : Capstan motor/FG
4 : FG cannot be detected.
Nov 07, 2009 | Sony DSR-1500 Mini DV VCR
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Mar 20, 2009 | Sony DSR-1500 Mini DV VCR
I have a problem.error code 35-000,DSR 1500AP.what is this?
error 35-000 on a dsr-1500 is a cassette compartment position error. check to see if something is obstructing the movement of the cassette compartment.
Jan 23, 2009 | Sony DSR-1500 Mini DV VCR
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
Error code C:31:70
this is servo IC problem.
May 31, 2007 | Sony DSR-45 Mini DV VCR
110 people viewed this question
k24674
jasbo
jasbo
