Question about Microwave Ovens
I need a manual for russell hobs convection microwave model rhmo150. thank you
  • Microwave Ovens Master
  • 17,129 Answers
Please check on this link: microwave.
Posted on Jan 10, 2013
SOURCE: russell hobs microwave oven
I am a recently retired appliance engineer of 20 years, microwaves are not normally things worked on yourself, i would be reluctant to help normally but yes there is an internal fuse ( a special quick blow type )just inside where the wire enters the cabinet on a small circuit board, if a replacement is needed it must be exact match bought from an electronic shop, microwaves are dangerous they store powerful electric and can still shock after removing the plug, if the replacement fuse blows, there is a fault elsewhere, and i do not recommend further self repair, work with safety
Posted on Sep 09, 2007
SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them service@saltoneurope.com. I could not find a manual on their website so I guess you will have to the above #'s wurstdude
Posted on Nov 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: russell hobbs combination microwave oven
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
It sounds like the switch is not activating properly, and the inside light, turntable and magnetron cooling fan are not coming on.
If the magnetron runs without the cooling fan, it will overheat and its thermostat will interrupt the power to the oven until it cools back down.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Dec 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
Ihave a russell hobbs convection/microwave/grill model no rhm2574 when programming oven when pressing start button the oven trips the power to the sockets this happens on all functions.whats wrong
It is likely that the heater element is faulty. These elements can fail with a ground fault. You should get a quote for repair as it may be more economical to buy a new one, and you get a warranty too.
Sep 20, 2016 | Russell Hobbs Microwave Ovens
I don't have a manual for this and was wondering if there is one available please Russell hobbs microwave model number RHMO150
Hello ... Kylie,
They are out there...
I try for the FREE manual SITES
(lots of scammers out there)... If these links do not direct you go to the COMPANY (RUSSELL HOBBS) site direct.
Hope this helps!!
http://www.bing.com/search?q=RHMO150+OWNERS+MANUAL&src=IE-SearchBox&FORM=IENTSR&pc=EUPP_
http://kitchen.manualsonline.com/support/other/microwave-oven/rhmo150-5238563
May 29, 2016 | Microwave Ovens
Need operating manual for russell hobbs microwave hob gts23
Is there a number on any tags on the oven?
If not, I would contact the dealer from whom you purchased the oven.
They should have contact information for the manufacturer.
Dec 02, 2011 | Russell Hobbs Microwave Ovens
Russell Hobs Juice Lady ....10007 it makes a lot of noise and is not juicing ...what is wrong? we don't have the user manual
THIS HAPPENS WHEN THE COUPLERS OR THE SHAFT ARE WORN OUT. REPLACE THE SAME AND IT SHOULD RUN FINE(THE PART CONNECTING THE JAR TO THE BODY)
REGARDS.
Jul 03, 2011 | Russell Hobbs Microwave Ovens
Russell Hobbs HOB CJ/AL28 Microwave not worring
it is easy to fix if you know what to do but it is best sent to a local repair shop
May 01, 2010 | Microwave Ovens
Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
Oct 31, 2008 | Kenmore 64002 Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Microwave Ovens Logo
362 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
