Question about Ingersoll Rand Air Tools & Compressors
Ingersoll Rand 115 air hammer does not work
The hammer does nothing when connected to air supply
hdpanama
  • 65 Answers
SOURCE: ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Posted on Nov 25, 2008
  • 1383 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
dee73ten
  • 40 Answers
SOURCE: 40 hp ingersoll rand rotary screw air compressor keep shutting
Defective bearings. Check Discharge air temperature, shutdown temp is 228
Posted on Aug 09, 2010
Runs but when you try running on a nut it just blows air. should the plates and drum be greased when rebuilt?
The air motor on the 285B needs to be oiled, the hammer section needs to be greased. The symptom described could be in the hammer mechanism, 285B's have 2 different side plates (item# 41) that sit atop the hammer mechanism, tools made from 2005 to 2007 use the old style side plate (item# 41) that has a small lip that need to sit looking toward the hammer case bushing (item# 44) when installed with the small lip facing in to the hammer will cause it to lock, tools made from 2008 to the present have a side plate that is flat on both sides and can be installed in either position. also check the hammer and anvil for cracks and pitting.
Follow this link to view the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80162944.pdf
Jun 01, 2011 | Ingersoll Rand Ingersoll - Rand 285B - 6...
The trigger does not work
the trigger valve is either ****, the o ring worn or the spring broken, remove trigger valve from the bottom of the handle, usually by removing the air intake
May 10, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
Check tiny allen head grub screw has not loosened on bottom trigger button and is catching on housing, otherwise one of the o-rings is missing off trigger plunger or piston. Carefull of spring behind trigger button when loosening allen grub screw. You will find the plunger behind trigger button.
Apr 22, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
IR 125 needle scaller not hammering or when it
put a couple drops of oil where the air line connects the tool......drain water from compressor
Nov 25, 2009 | Ingersoll Rand 125 Standard Duty Needle...
Ingersoll Rand M # 10T3NL Trouble
your problem seems to be that the non return valve is passing ,your local i/rand dealer can supply a new seal,there not expensive
Oct 08, 2008 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
