Question about Vacuums
I have a Dyson DC 32 animal. The turbine head vibrates and reduces in speed. I have cleaned the head and the drive belt is still in place but the vibration still persists.
  • 83 Answers
SOURCE: Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
Posted on Jul 30, 2009
  • 175 Answers
SOURCE: how do I change belt on dyson dc 07 animal
You can't change the belt. There is a factory tool that is needed to do it.
Posted on Dec 02, 2009
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
  • 53 Answers
SOURCE: my dyson dc17 amimal's main turbine head is not
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
Posted on May 31, 2010
  • 377 Answers
SOURCE: Dyson DC 25 Dyson Ball animal. The bottom brush
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Posted on Oct 08, 2010
Dyson DC28 wont come on after cleaning filters
Support for DC28 Animal - Dyson
www.dyson.com/support/dc28/dc28-animal
DysonGet expert help for your DC28 vacuum from Dyson Support. ... as usual · Mini turbine head not working properly · Machine won't switch on or turns off on its own ...
How to Clean a Dyson Vacuum - Ask Anna
askannamoseley.com/2011/02/how-to-clean-your-dyson/
Feb 1, 2011 - Today I'm going to give you a tutorial on how to clean a Dyson vacuum. ... After you do a quick rinse take a washcloth and some dish soap and wipe the ..... My hubs will be so happy that I won't be paying someone to do this. ..... I have come as far as cleaning out the filters and will do the traps later today.
Amazon.com: Customer Discussions: Dyson Clogging/ loss of suction: Fix
www.amazon.com/forum/dyson/Tx2SY4FCNIUYI73
Amazon.com, Inc.Sep 25, 2009 - I can't veryify all canisters come apart the same exact way, but the problem ... That being said, you can clean your dust filtration unit and it is easy to do. ... using air or water won't clean the dust filtration canister while it is together. ... After2 years, my Dyson DC17 has lost suction in the upright mode, but the ...
DC28 Cleaner Head Replacement Removal - YouTube
? 17:19
https://www.youtube.com/watch?v=yERbv8owKU4
Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
My beater brush isnt rotating and I am sure I cannot check the belt by myself after looking at this video. ... I have ..
Jan 24, 2016 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
Brushbar not turning Clutch check - Dyson
www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
Resetting the brush bar (Official Dyson video) - YouTube
? 3:52
https://www.youtube.com/watch?v=AiKnefEr7ns
Jan 16, 2014 - Uploaded by AskDyson
How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
Dyson DC44 - Remove & clean the Brush Bar - An owners ...
? 4:13
https://www.youtube.com/watch?v=_0a71p84sp8
Nov 12, 2012 - Uploaded by Tom Strong Reviews
Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
Dyson DC54 Support - Turbine head not working properly
https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
Jan 24, 2016 | Dyson Vacuums
How to I fix the stuck power cord on the Dyson DC23 Turbine Head Animal?
Hi Saule, it's Jack at Dyson.
I'm sorry to hear your DC23 Turbine Head's cord seems to be stuck. If there's an issue with the cord reel mechanism, your machine may need a repair.
We'd be happy to help you arrange this, and will also be able to confirm if this is covered under your Dyson parts and labour warranty. Please note, we would advise against trying to repair the machine yourself in case damage is caused - if your vacuum is within our warranty period, this could also void any remaining cover.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) to discuss your options with our experts.
We'll look forward to speaking with you.
Dec 20, 2014 | Dyson Zorb Mini Turbine Head, NEW Animal...
I would like to remove the clear cover over the brush bar on my Dyson DC-28 so that I can clean it. It's filthy and I cannot clean it with the brush bar in place. Is it possible to do this myself?
Hi there, it's Jack at Dyson.
DC28's cleaner head is a complex assembly which is not engineered to be dismantled. We'd advise against attempting this - any damage caused would not be covered under your Dyson warranty.
If you'd like some guidance on maintaining your DC28, please email askdysonUS@dyson.com and someone will be in touch as soon as possible.
Nov 23, 2014 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
How do I get a new belt to repace a broken one in a DC23 turbine head
The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
Dyson dc 47 head won't turn on
If the brush bar in your DC47's carbon fibre turbine head isn't rotating it's worth checking it's set correctly. You can turn off the brush bar manually to clean delicate rugs, and it's possible the brush control may have been accidentally activated:
It's also a good idea to check that the brush bar is free of any threads or hair, and that there are no obstructions in the cleaner head which could be jamming it:
This should resolve the issue, but if you'd like some further advice from our experts when you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US) or 1800 239 766 (AU).
Jul 11, 2014 | Dyson DC47 Animal Canister Vacuum Cleaner
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
Apr 07, 2014 | Dyson DC39 Animal canister vacuum cleaner
Beater bars not turning
I'm sorry to hear you're having difficulty with your DC23. This model doesn't include a traditional user-replaceable belt - the drive system is engineered to last for the lifetime of the machine.
If your machine is a DC23 Motorhead, please take a look at the video above to clear any obstructions from the brush bar and cleaner head, and to reset the machine.
If your DC23 includes an air-driven Turbine head, please follow the steps shown in our online Support guide to make sure everything is correct with your vacuum: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/turbine-head-not-working-properly/check-the-plunger
If you'd like some further advice from our experts after you've given this a try, please contact the Dyson Helpline directly - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
If a repair or replacement part is needed, we'll be happy to confirm if this is covered under your vacuum's 5-year warranty.
Best wishes,
Jack
Dyson Online Customer Service
www.dyson.com
Nov 18, 2013 | Dyson DC23 Bagless Canister Cyclonic...
Dyson blueprint beater bar won't turn
The Dyson DC 17 has a rug / floor switch on the head of the vacuum. Please check to make sure the switch is in the Rug position. If the brush roller still does not turn then you have broken the belt and need the following part.
Dyson DC17 Geared Drive Belt, Genuine Dyson Part # 911710-01 - Free Shipping
Apr 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson power head stops when on carpets, cleaned brush out, still happens.
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Jan 31, 2010 | Dyson DC11 All Floors Bagless Canister...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
