Question about HP Photosmart M407 Digital Camera
The image display screen is dark, I can see nothings on the screen. Only picture size setting,SD card, batteries and no. of remaining pictures shown. I have read your suggested solution, however there are only similar question and reason. Will you please show me the solution for my problem? Could it be fix? Thank you for giving me the best solution, I'll try.
    New Friend:
I have the same problem,with my HP Photo smart M407,i cant see anything,when i hook it up to a power source it show barley any display
Posted on Aug 13, 2013
SOURCE: transfer images
IF you have a USB cord, you can possibly plug in your camera an PC and copy all the pictures to your computer.
Give it a try.
Posted on Jan 07, 2008
SOURCE: LCD Display Blank
When the camera is turned on, the LCD diaplay screen is blank (dark
Posted on Feb 06, 2009
wavoconqueso
  • 57 Answers
SOURCE: card unreadable display and can't retrieve images on sd card!
If this were mine I would take it to Walmart or something similar and load the card into their photo machine to see if it says the same thing. If theirs won't read it the card is probably hosed and your photos are gone.
Posted on May 28, 2009
tommya300
  • 724 Answers
SOURCE: hp m417 says error saving image when i try to save to card
did you check your SD card to see if a different reader sees if and you can read wirte to ir tey tio reformat it just for general purpose/
Posted on Jul 27, 2009
SOURCE: It has just stopped showing a picture in either
I gave the camera a jolly good bang!!!
The pictures then appeared.
I hope this will last.
Gerald Slee
Posted on Jan 20, 2010
Pentax ist d keeps saying delete after each picture i take before picture is shown
You can try to reset camera settings to default from the menu.
And fimware update could help if the software causes the problem.
http://www.us.ricoh-imaging.com/support/download-details/417
SD card write protection lock also should be off.
Jul 27, 2013 | Pentax *ist D Digital Camera
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
Panasonic Lumix DMC-TZ3 Digital Camera: The camera LCD display is extremely dark with shadows/outlines of reddish pink hues and the same image is shown when a picture is taken. I have tried transferring...
Did u check the settings of the camcorder? see the setting there you got contrast settings if its low then you'll get dark images or its exposer meter's problem U check the exposer meter's reading and see aparture also.
Mar 09, 2011 | Cameras
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
I put my SD card in but nothing happens. I've double checked that the card contains picture files using a 24 in 1 USB Card Reader. I'm using a Kingston microSD with adapter. When I take the SD card out of...
Check the way the SD card was formatted. FAT16 or FAT32. Save the images out to the computer, Reformat the SD card to FAT32, add the images. If that doesn't work, do the same with FAT16.
Dec 17, 2017 | Matsunichi 8 digital picture frame
The camera won't register an image to take a picture of.
LCD monitor electric film contacts must be fixed. If you can not do it yourself then please contact with the nearest authorized Canon Service. I think it is too easy to fix it so it is not need much money.
Feb 28, 2010 | Canon PowerShot S2 IS Digital Camera
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
Memory Card
chances are its the size of the pictures the camera is set to take,you will have to make them smaller, and lower quality to raise the amount of pictures you can take.The instructions on how to do that should be in the manual, or you can try the 1 i found on their site.
Changing the Resolution and Compression
1. With the camera power on, press the <FUNC./SET> button.
070.gif 2. In the Function menu select L* or 295.gifusing the 021.gifor 026.gif button.
a550rescomp.gif * The current setting is displayed.
3. Select the resolution or compression you wish to set using the 028.gifor 023.gif button.
You can shoot the image right after selecting settings by pressing the shutter button. This screen will appear again, once the image is shot.
6. Press the <FUNC./SET> button.
7. Shoot the image.
i hope that helps,later you might want to invest in a bigger memory card, 16mb is very small.Id go for a 512mb or a 1gb SD memory card ,then you'll be able to take more larger quality pictures.
May 25, 2008 | Canon PowerShot A560 Digital Camera
Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Dec 07, 2007 | Sanyo Xacti HD1 Memory Card Camcorder
HP Photosmart M407 Digital Camera Logo
47 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
