Question about Amana Refrigerators
Amana 12830922 refrigerator portion not cold
Refrigerator is not cold, freezer is working fine
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
landsend
  • 1066 Answers
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Posted on Mar 22, 2009
heatman101
  • 43501 Answers
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Amana ABB2524DEB
The ice buildup is the problem. Cold air must pass from the freezer to cool the refrigerator.
Link is to youtube videos about that problem.
bottom freezer refrigerator not cooling YouTube
https://www.youtube.com/results?search_query=bottom+freezer+refrigerator+not+cooling
Look at more than one video to find the best one for your problem.
Sep 03, 2014 | Amana Refrigerators
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Refrigerator stop working, freezer fine
What is the model number of your unit?
Oct 31, 2012 | Amana Refrigerators
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
I have an Amana ARB2217CSL. The freezer is working fine, but the refrigerator section is no longer staying cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Amana ARB2217CSL Bottom Freezer...
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
Refrigerator will not cool
pull freezer back panel. is fan moving, is there frost built up on coils if so then defrost problem
Apr 24, 2010 | Amana ABB1927DE Bottom Freezer...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Frozen food in refrigerator
turn your freezer up all the way and your refrigerator down a little. this will block some of the airflow going to the refrigerator.
Jul 05, 2008 | Amana Refrigerators
Refrigerators Logo
123 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
